fuel injection repair. - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition
Hardcore Tech and Competition Strictly HARDCORE tech info and questions and also autocross / racing discussion!
Old 03-14-2005, 07:58 PM   #1 (permalink)
Zzzz
CrawlingEye's Avatar
View CrawlingEye's Photo Gallery
I'm thinking temporarily I'll leave the stock fuel line intact (As some of you may know, I have a bent fuel line).
However, to rectify the issue, I'm thinking of using stainless braided rubber or teflon line and flaring it out or using a compression fitting with an adapter fitting.
any sugguestions on which would work best?
From what I gather, it's difficult to get something to hold onto fuel injection since it runs at such high psi (in comparison to carb vehichles).
I've tried searching this (on google and here) and have come up with nothing.
I know since I'm flaring I can use any (reasonably close) line to fit it. I'm thinking of running -6AN. thanks!
-mark
'93 Camry LE (5S-FE)
CrawlingEye is offline   Reply With Quote
Old 03-15-2005, 02:06 AM   #2 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
You can't flare stainless steel braided hose. Only hard line.
Theres adapters you can use to go from tubing (hard line) to AN.
Male AN to tubing adapter:
http://www.amstreetrod.com/165008ERL.php4
Female AN to tubing adapter:
http://www.amstreetrod.com/165108ERL.php4
Stainless braided rubber hose works fine on fuel injected vehicles.
"Skoolin' the unlearned!"
Old 03-15-2005, 08:33 AM   #3 (permalink)
Zzzz
Sorry, 88. I meant to say flaring the hardline and using a flare to AN fitting.
Thanks.
-mark
