ALuminum wheel performance question - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition
Hardcore Tech and Competition Strictly HARDCORE tech info and questions and also autocross / racing discussion!
Old 03-14-2005, 09:53 PM   #1 (permalink)
sloppybeak's Avatar
View sloppybeak's Photo Gallery
Question ALuminum wheel performance question
HI,i would like to askif its worth the 250.00(for outlaws aluminum wheels) or 600.00(for weld aluminum wheels)? Is there a noiticable gain in pickup/acceleration?I would probably get the outlaws sicnce thieves target the welds.I have steel wheels right now(14X6),and im not concerned with looks-only performance.I would shave about 80 pounds off the weight if I switched to aluminums. Also,what is the difference in sprung versus unsprung weight as it relates to steel vs. aluminum wheels,and which wheel has the advantage in handling...THANX
1989 2wd 22R 170,000 mi.,Mallory Hyfire Igntion/coil,Magnacore wires,K/N filter,Silver-E Steer stablizr, Rear Swaybar,Edelbrock shocks,Cooper 205-70-14's/14X6 Steelies, LC Eng dbl. row time chain w/ cast iron oilpump, Porterfield R4S Discs/Carbon Kevlar drums, Ice Cold AC, Sony/Linear Pwr sound
sloppybeak is offline   Reply With Quote
Old 03-15-2005, 01:48 AM   #2 (permalink)
Immortal
View Kwanza's Photo Gallery
Wheels are wheels. The only time they can affect performance in handling and acceleration, is their weight, and size. That should be enough info for you to figure it out... I hope...
It's ok to be naked, girl... I'm an Artist!
95 AT200 Celica ST: Stockish Daily Driver
84 AE86 Corolla GT-SR5 Hatchback: GT-S Swap with JDM Smallport 4AGE and goodies...
84 AE86 Corolla GT-SR5 Hatchback: GT-S Swap with Silvertop 20 Valve 4AGE
91 SW2X MR2 N/A: Rare hardtop cruiser
Kwanza is offline   Reply With Quote
Old 03-15-2005, 11:17 AM   #3 (permalink)
sloppybeak's Avatar
Question that wasnt any help at all
Dude what the F* are you talking about?? youre on Crack...
Old 03-15-2005, 12:52 PM   #4 (permalink)
Lead-Foot
S92GT's Avatar
View S92GT's Photo Gallery
as far as one brand of rims outperforming the other, doesn't matter, really. a lighter wheel is better, I guess, however, it's really just something to attach tires to, tires really affect handling/performance.
and if you are worried about theft, get some locking wheel lugs, and save youself a headache.
S92GT is offline   Reply With Quote
Old 03-15-2005, 01:20 PM   #5 (permalink)
Zzzz
CrawlingEye's Avatar
View CrawlingEye's Photo Gallery
tires of course play the grip roll, but if you have a taller rim, you'll use a thinner sidewalled tire which will effect body roll and so on.
similarly, a wider rim and wider tire will give better traction.
-mark
'93 Camry LE (5S-FE)
CrawlingEye is offline   Reply With Quote
Old 03-15-2005, 06:19 PM   #6 (permalink)
spin turbo hammy... SPIN!
Hamsterman's Avatar
iTrader Score: 30 reviews
View Hamsterman's Photo Gallery
Other things you have to consider in wheels is duarbility... I do not know much about aluminum wheels, but especially if you are doing a DD application, you need something that can withstand a pothole hit here and there... A dented wheel is bad news, and you can spend more $$$ replacing wheels than just buying higher durability ones up front
Lick first... ask questions later
Hamsterman is offline   Reply With Quote
Old 03-17-2005, 12:53 AM   #7 (permalink)
View shawnstam's Photo Gallery
flywheel makes no diff
the flywhell makes no diff on a GTS 2004 i put a fidanza on and it feels the same as stock. and that no shit
celica GTS 2004
shawnstam is offline   Reply With Quote
Old 03-17-2005, 01:54 AM   #8 (permalink)
I am just a newbie!
Tony the Tiger's Avatar
View Tony the Tiger's Photo Gallery
For tiny-ass 14" wheels, who cares... The tires will weigh more than the actual rim anyway.
You are better off getting a set of performance tires which are usually much lighter than regular all seasons/touring tires.
And I don't think it will shave off 80 lbs. That's 20 lbs per wheel. At most you will shave off 10 lbs per wheel unless you get into forged wheels which is probably $350+ per wheel.
* Goal for 2012 -- 200+ MPH in the Camry
Tony the Tiger is offline   Reply With Quote
