Low Idle when cold and when AC is on - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition
Hardcore Tech and Competition Strictly HARDCORE tech info and questions and also autocross / racing discussion!
Old 03-30-2005, 02:44 PM   #1 (permalink)
View Tom Simon's Photo Gallery
Hi guys, I'm new to this forum. I just bought a used 95 Celica GT 'vert (90k miles, all stock) I have a technical questions regarding idle and idle speed, then rear window adjustment (I want to reduce the wind noise a little). I'm overall impressed with my first Toyota, but it needs a few little issues fixed before it is a great car.
Problem #1: low idle when cold, low idle when AC compressor cycles on. When the AC compressor cycles on, the idle goes down a couple hundred rpm and the engine runs rough
I suspected the fast idle actuator. I pulled the vacuum hose that connects to it, which caused the stop to move and idle to raise. I reconeected the hose, the stop retracted, idle dropped back.
What should I look at and check for at this point?
Problem #2: the rear quarter windows don't seal very well against the side (door) glass, near the sill (top of the door). There is about 3-4mm gap, but the glass is tight at the top.
Is there some adjustment at the regulator for angle, or do I need new window rubber? It whistles pretty bad over 65-70mph, going slower isn't what I had in mind, but I want to keep my hearing LOL
thanks in advance
Tom Simon is offline   Reply With Quote
Old 03-31-2005, 04:18 AM   #2 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
For problem #1, check the a/c idle up vsv itself.
"Skoolin' the unlearned!"
Old 04-01-2005, 06:24 PM   #3 (permalink)
thanks for the reply,
uh... what is a "vsv" , maybe "vacuum servo valve?"
If so, where would I find it or what does it look like?
sorry for the bonehead question, but I'm not sure of the terminology
Old 04-02-2005, 03:04 AM   #4 (permalink)
Grenaded piston
88 LE's Avatar
vsv = vacuum switching valve
http://www.autozone.com/servlet/UiBr...3d8013ed9b.jsp
Link above has info for a Camry, but the valve looks the same on your Celica.
