background: 20v swap into my ae86 sr5 (carb->efi)
My mech and I are basically stuck on the wiring part hoping you have some insight before i start running wires from diagrams. I have everything plugged where it needs to be, exept the wires that go inside the car from the ECU dont have anything to plug into... dasboard wont work.
Anyways, on that third ecu plug that goes inside (dashboard), i have it but its cut and can't really run the engine without power feeds, ignition switch etc...you have any thoughts on what i should do?
BTW you may like this, it has the 20v wiring diagrams and ecu pinouts for both 16v (inc 4agze) and 20v engines:
http://www.turbocorolla.com/tech/default.htm
i dont know if the gts dashboard/dash harness works, but let me know
***this topic was moved from the corolla section here...cause i think this is the proper place
