Tire pressure tips - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition
Hardcore Tech and Competition Strictly HARDCORE tech info and questions and also autocross / racing discussion!
Old 08-04-2002, 11:24 AM   #1 (permalink)
There is no substitute.
EKam's Avatar
Gameroom cash: $697365
iTrader Score: 6 reviews
View EKam's Photo Gallery
Tire pressure tips
This sounds a bit logical to me so I'm posting this here.
This was given to me by CamryMan.org user "cdssolara" and it is the best formula for tire pressure that I have read.
Take your vehicle weight plus driver and divide by 100, this is your base.
Add 2psi to that if you have a OE suspension.
Add 2 more psi on the heavy end of your car (front for our cars)
So you say that you car weighs 3400lbs that means 34lbs is the base, so for a Camry with stock springs 38 front 36 rear, with a performance springs it is 36 front and 34 rear ...
Play with it from there to suit your taste. more pressure for performance driving and less for driving grandma to the store.
EKam is offline   Reply With Quote
Old 08-04-2002, 05:17 PM   #2 (permalink)
The terrorist
View Xenon's Photo Gallery
That sounds very reasonable actually... Thanks elegantcam, I'll use that formula and maybe I'll notice a difference...
My sexy AE92 http://members.cardomain.com/ababan
Xenon is offline   Reply With Quote
Old 09-12-2002, 07:13 PM   #3 (permalink)
View Deep's Photo Gallery
What do most of you guys run on the street and what kinda car/suspension mods do you have?
Deep is offline   Reply With Quote
Old 09-16-2002, 03:11 AM   #4 (permalink)
Bare backs like Tarzan
View DaksGT's Photo Gallery
And add 4 more on top of that
DaksGT is offline   Reply With Quote
Old 09-28-2002, 06:21 PM   #5 (permalink)
The terrorist
My friend was telling me today that 32psi is too low for my Toyo Proxies! He apparently used to put 38psi in them to get the best performance!
Old 10-03-2002, 08:43 PM   #6 (permalink)
Old Skool VIP Style
View 86CRESSIDA86's Photo Gallery
i put 40psi in my potenzas, gives a nice firm ride, but still grips well and the tires last a good time
Ian K
2003 20th Anniversary VW GTI 1.8T 6spd
86CRESSIDA86 is offline   Reply With Quote
Old 11-12-2002, 07:27 PM   #7 (permalink)
View cdssolara's Photo Gallery
I just joined this forum recently, and I see I got credit for the formula in the first post!
Anyway, the formula is just for a basis point. A lot of people who like to drive fast will probably want to up the pressure a bit. It will keep the tire a little stiffer and provide quicker cornering. Most autocrossers like to keep the pressure higher than what is recommended by the tire manufacturer. For drag racing, you want it lower.
cdssolara is offline   Reply With Quote
Old 11-15-2002, 01:09 PM   #8 (permalink)
View NASTY's Photo Gallery
shouldnt the pressure be the same regardless of tire?
i always thought that upping it more than 32-33 (toyotas reccomendation) would cause the center wear quick
'01 SLE V6
NASTY is offline   Reply With Quote
Old 11-15-2002, 10:04 PM   #9 (permalink)
For normal driving, the recommended pressure is probably OK. Increasing the pressure a few psi is probably not going to cause any noticeable difference in how the tires wear. At the recommended pressure, however, the handling will probably feel pretty "sloppy" during aggressive driving because the tires will be a bit soft for quick turning. In an event like an autocross, you'll be putting a lot more pressure on the edges of your tires than you will on the center.
Old 12-03-2002, 11:50 PM   #10 (permalink)
View daidaikonnootoko's Photo Gallery
Wow, that's really good information to have! Thanks cdssolara
I never really thought of it in an organized formulaic sense.
Right now I'm running Yokos at 41psi back and 44psi front (little more psi than normal) but I don't know if my gage is completely accurate. Regardless, the handling/cornering is excellent compared to what they used to be (32 and 31ish). Feels good.
DAI_DAIKON_NO_OTOKO!
(thanks to 91camryDX for the spec info)
daidaikonnootoko is offline   Reply With Quote
Old 12-04-2002, 07:48 PM   #11 (permalink)
How's the ride comfort at that pressure? Is it noticeably firmer?
Old 12-31-2002, 09:01 PM   #12 (permalink)
View rolla1997's Photo Gallery
yeah on my rolla i put the pressure at 34 PSI on my stock tires. Had them at recommended 30 psi and way too much roll around corners cuz stock suspension is really soft.
rolla1997 is offline   Reply With Quote
Old 01-07-2003, 03:28 AM   #13 (permalink)
View superpilun's Photo Gallery
I'm not sure I agree that the heavier end should be inflated more. In ff cars, the front tires do a lot more work so they heat up more, this usually means that during competition you need to lower the pressure some so that when the tires get to operating temperature, you have optimum handling. More pressure does not mean better. The pressure should be such that during competition, the temperature across the tire (inside, middle, outside) is the same. If over-inflated, the middle of the tire will be hotter, and you are not using the tire to its full potential. If the inside is hotter, you have too much negative camber. And so forth. The only real way to know if you are at optimum pressure is to get a tire pyrometer (temp. gauge). However, sensitive drivers can tell the difference between an under-inflated understeer and an over-inflated understeer in FF cars. Go read up on www.turnfast.com it's an excellent resource.
superpilun is offline   Reply With Quote
Old 03-29-2003, 11:39 AM   #14 (permalink)
The terrorist
Your advice is great, but you don't want ober inflate your tire to the point wehre the car starts skipping on the smallest bumps. I cannot have my tires over inflated because I have a very stiff suspension, therefore if my tires were very stiff I'll have an unbearable ride!
Old 03-29-2003, 02:18 PM   #15 (permalink)
View Tex97's Photo Gallery
I'm running 35psi on my Goodyear Aquatread 3's(They suck, but they are brand new-came with the car) and stock suspension.
I was running 32 but it was too sloppy for me, 35 seems like a good mix of road feel and comfort.
97' Camry XLE V6
Tex97 is offline   Reply With Quote
