Info on timing belt replace... - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition
Hardcore Tech and Competition Strictly HARDCORE tech info and questions and also autocross / racing discussion!
Old 04-11-2005, 11:18 PM   #1 (permalink)
View guam_boy00's Photo Gallery
hey wassup guys...I'm gonna do a timing belt R/R on a 88 cressida. And I was wondering what seals really need to be replace and what is the difficulty for a first timer for this car... Or any advice would be really appreciated thanks guy...
guam_boy00 is offline   Reply With Quote
Old 04-14-2005, 07:27 PM   #2 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
its easy, get the pulleys off andpop the timing cover off the belt, the crank pulley bolt will be pretty tight and getting the pulley off the crank can be a cussin affair, look in the manual and get the timing marks lined up, loosten the tensioner and slip the old belt off, slip the new one on and tighten it up just snug, reassemble
Old 04-23-2005, 02:46 AM   #3 (permalink)
View rddrgn1's Photo Gallery
re: timing belt
a trick i always use is to take a paint pen, mark the belt and the gears (cam AND crank) directly on a notch, and an arrow next to the top mark pointing out so you know which mark is the top,BEFORE you take it loose. then transfer the marks to the new belt EXACTLY where the marks are on the old belt and re-install, matching the marks on the gears. if you get the marks right you can't go wrong. also, look real close for oil seepage at the crank and cam seals, if they're not leaking don't mess with them - just be gentle putting the crank damper back on so you don't hose the seal in the process.
rddrgn1 is offline   Reply With Quote
Old 04-23-2005, 09:40 AM   #4 (permalink)
Toysrme's Avatar
View Toysrme's Photo Gallery
Cool
Finger nail polish = free ownage.
Be sure to use a bright color on the crank so you can actually see it with a timing gun.
AIM/Yahoo Toysrme257th
Now with Turbo!
