Looking for input on 4EFTE ECU wiring - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition
Hardcore Tech and Competition Strictly HARDCORE tech info and questions and also autocross / racing discussion!
Old 04-18-2005, 01:17 AM   #1 (permalink)
The Mad Scientist
View Dr Tweak's Photo Gallery
I'm just about done with the wiring on this 4EFTE swap, and I have a couple questions. There are several wires that go from the ECU to under the dash, and they are not on the engine wiring diagram that I have. I opened the ECU and looked on the PCB, and the IDs for the wires are:
OD2
P
BL
M
CCO
ELS
I have figured out that OD2 is for the overdrive switch, CCO is for the exhaust temp, and ELS goes to the stop light switch for the idle-up. However, I'm totally lost on P, M, and BL. Any input?
-Dr Tweak, Toyota engine swap wiring expert extraordinaire
Check out some of the swaps I've done at http://www.phoenixtuning.com/swaps.html
Dr Tweak is offline   Reply With Quote
Old 05-06-2005, 08:25 PM   #2 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
Have ya tried checking alldata?
Old 05-06-2005, 10:06 PM   #3 (permalink)
The Mad Scientist
Yeah that's what I use. Anyway this an old thread. Check it out:
http://www.toyotanation.com/forum/t76430.html
Old 05-23-2005, 07:22 PM   #4 (permalink)
View Hey_hi_ilya's Photo Gallery
hey, can someone help me out,
i did a swap for a tercel 93 using a 4efte, the motor has a bad turbo on it, it smokes, what is the best turbo to put on the 4efte and also my motor studders at about 4 thousand rpm and doesn't go higher.
what could be the problem?
Hey_hi_ilya is offline   Reply With Quote
Old 05-23-2005, 10:06 PM   #5 (permalink)
The Mad Scientist
You can use a T25 or a small T3.
For the other problem, email me at drtweak@phoenixtuning.com
Old 06-11-2005, 01:18 AM   #6 (permalink)
Toymods Member
View Toobs's Photo Gallery
Check out this page: http://toyotagtturbo.com/wiring/index.html
Its got a bunch of wiring diagrams for the 4EFTE.
P could be PIM from the map sensor.
P could also be PSW which is the signal wire from the TPS.
M could actually be W that you read upside down which would be the engine check light.
BL could be +B1 which is one 12V wires.
Use those diagrams and also compare the wire colours not just the PCB markings.
Toobs.
Member 179.
Toymods Car Club Australia
http://www.toymods.org.au/
Toobs is offline   Reply With Quote
Old 06-11-2005, 01:23 AM   #7 (permalink)
The Mad Scientist
Got those diagrams, which by they way, were almost totally wrong for this engine.
Thanks for the ideas, but no, all of those wires had been accounted for. These have something to do with the auto tranny I think.
At any rate the car is completed and is on the road at this time.
Old 12-06-2005, 10:24 PM   #8 (permalink)
View opmnyc's Photo Gallery
how can i get some references on diagrams for the 4efte? I too have empty slots in 16 pin connector of ecu, bc, ac2, pim, and egw. are these vital in car operation? thanks in advance
opmnyc is offline   Reply With Quote
Old 12-07-2005, 06:47 AM   #9 (permalink)
The Mad Scientist
I'm pretty sure that I answered your question on another forum. You can get the diagrams from www.toyotagtturbo.com
-Doc
