Of course it would kick ass, that wasnt my point though. To swap in a GZE and mod it up would cost just as much, if not more than it would to just do a 20V swap. Not to mention the labour involved in the engine swap...
My point was that a 20V head is the easier job to perform, and for the money its a better deal.
"Technology is the only substitute for cubic inches"™
you might as well just swap a whole 20V engine.. what's the point of swapping the head? unless you happen to have a set of 20V pistons lying around and a 20v head for cheap..
__________________ mr sinister
1987 ae86 - black hatch
--- GTP Light Tune SPL Super Lace Edition
2001 VW GTI 1.8T
--- "Racing" pedals. my website
yeah exactly.. as i understand it, the 20V block is a 7 rib block, like the redtop or gze.. but it uses a different crank, rods (?), and pistons..
so you wuld have to take the 16v head off, change to 20V pistons (which probbaly wouldn't even work on a blue top, the piston wrist pin size is probably wrong) then bolt the head back on,..
you would still have to worry about the dizzy/firewall problem, still have to either replace the ecu and wiring harness with the 20v versions or get aftermarket ecu, still have to fab those waterpipes and all that other fun stuff..
just do a "normal" 20v swap.. its probalby LESS work..
2001 VW GTI 1.8T
I agree...... You would need more than just the head to make it work well..... Physically, the 20v head will "bolt" to the 4a block, but consider you need the proper distributor, and it is the 3sgte style, with G-, Ne, etc unlike the regular NA distributor. Thus, you cannot run it easily with a regular 16v ECU. Remember that the radiator/heater piping is all different as well. The 20 vavle uses 4 seperate throtlle bodies, and the idle control is with an ISC valve, like the GZE and 3SGTE. That is another issue, you cannot control the ISC with a regular US 16valve ECU....
My suggestion, get a complete 20v with wiring harness, AFM, and ECU. Since they were never used in a US model car, the engine importers that get stuck with them sell them cheap... A good importer is SOKO American..... if calling the Franklin Park office in the Chicagoland area, ask for Cheston, he is a Toyoto-phile!
