volt meter the VF signal to see if it's running lean / rich.
Then volt meter the o2 sensor. It oughta read 780-830mv a split second after you hit the gas, and shouldn't drop to 750mv.
When you swapped the engine, did you keep the stock air meter? You should have if you didn't!
AIM/Yahoo Toysrme257th
Now with Turbo!
