NEED HELP: 20V camshafts - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition
Hardcore Tech and Competition Strictly HARDCORE tech info and questions and also autocross / racing discussion!
Old 06-03-2005, 09:08 PM   #1 (permalink)
View micro214_kp61's Photo Gallery
i'm planning on getting some aftermarket cams for the silvertop 20V. i have problems deciding on what i want (duration and lift). this i know, i want to keep the VVT, make the car still streetable but have the powerband bump to maybe operational rpm of 4500-8500. i still haven't decided if i'll be needing to change the internals (shims, valve springs, etc.). i found some aggesive cams from tedcomponents but i want to see if there's more out there available. anyone knows of any other companies making camshafts for the 20V? thanks!
btw, the car is meant for street and occassional track runs!
1982 Toyota Starlet (SP61) boosted since 2007
micro214_kp61 is offline   Reply With Quote
Old 06-04-2005, 01:12 AM   #2 (permalink)
Beams SV21
da_horse's Avatar
View da_horse's Photo Gallery
Toda Camshafts
what size are u planning on running? and are you going to use the stock ECU. From the cars that i've seen most of the guys say that after 264 or 272 is the max they would go on stock ECU. Plus you will need to get some adjustable cam gears too. but i'm pretty sure you know about all this
Cheers
Huy
1989 BEAMS 3S-GE SV21 Camry
da_horse is offline   Reply With Quote
Old 06-04-2005, 08:04 AM   #3 (permalink)
da_horse... i've checked the TODA site before. i'm looking more into the small companies. i know there's a site located "down under" called kelford cams. i've been in contact with them but still looking for other companies. yeah, know that i have to use adjustable cam gear on the exhaust side and no i won't be running with the stock ECU, got a good deal on a standalone ecu.
btw, i'm looking at anywhere north of 272, maybe like a 290+ with maybe 8.5+ duration. but i don't think i'll be able to run the VVT with this though. we'll see!
thanks for the reply.
Old 06-04-2005, 08:25 AM   #4 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $271521
View REN69's Photo Gallery
I swear.. none of the GTA guys running silvertops/blacktops run OEM ECUs.. well, all the crazy filipinos anyways. everyone is running Haltech.
Old 06-04-2005, 02:56 PM   #5 (permalink)
hehehe.. REN, it's true what they say, once you've seen a Haltec controlled engine run.. you won't go back to OEM.
