NEWBIE Q#2: hp - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition
Hardcore Tech and Competition Strictly HARDCORE tech info and questions and also autocross / racing discussion!
Old 09-01-2002, 08:50 PM   #1 (permalink)
operation boro thunder
View project trueno's Photo Gallery
NEWBIE Q#2: hp
ok this one is more simple...what does bhp stand for...? sometimes u guys say hp and bhp, are they same, or are they not?
also what initials stand for hp AT THE WHEELS? (or is there none?)
thanks :o
more questions to come
project trueno is offline   Reply With Quote
Old 09-01-2002, 09:04 PM   #2 (permalink)
1nzfe addict
View toymaniac's Photo Gallery
whp= wheel horse power
chp= crank horse power
bhp???
Toymaniac ADM. ClubEchoQuebec.com
toymaniac is offline   Reply With Quote
Old 09-01-2002, 09:19 PM   #3 (permalink)
ya doesn't it piss you off? what the hell is BHP?
Old 09-01-2002, 10:43 PM   #4 (permalink)
TN Track day addict
View Lafora's Photo Gallery
bhp = brake horsepower
brake horsepower is the actual or useful horsepower of an engine, usually determined from the force exerted on a friction brake or dynamometer connected to the drive shaft.
should i elaborate further on what that means?
My blog
Fast and cheap won't be reliable.
Cheap and reliable won't be fast.
And fast and reliable won't be cheap
Lafora is offline   Reply With Quote
Old 09-01-2002, 10:50 PM   #5 (permalink)
ok got it :wink:
so you would refer to a dyno'd hp figure BHP right?
Old 09-01-2002, 11:02 PM   #6 (permalink)
TN Track day addict
from a guy's site who's from the UK
Three different horsepower values are used in talking about engine performance: (1) Indicated horsepower is the theoretical efficiency of a reciprocating engine, which is determined from the pressure developed by the cylinders of the engine; (2) Brake or shaft horsepower is more commonly used to indicate the practical ability of the engine, or the maximum performance, which is the indicated horsepower minus the power lost through heat, friction, and compression; (3) Rated horsepower is the power that an engine or motor can produce efficiently for sustained periods of time.
and no, bhp != hp from a dyno. Brake horsepower is a common term and refers to the power measured at the crankshaft using a "prony" brake. A prony brake was a simple lever that was connected to the crankshaft with a brake. As the brake is applied, the lever would deflect and power was indicated.
in case you are still confused, lemme reiterate. Brake horsepower is a calculation where the engine horsepower is measured at the point of output with no load from a chassis or any accessories and with fuel and ignition operations under ideal conditions. Brake horsepower is often called gross horsepower today.
i just don't want you to confuse bhp with dynoed hp which usually means whp
My blog
Old 09-01-2002, 11:13 PM   #7 (permalink)
so WHP is the hp rating WITH load from the chassis and pretty much everything the power needs to go through all to way to the wheels right?
where or when does one use BHP?? :-? shouldn't the figure be far off the WHP figure since it bears no load? (besides the heat and friction as mentioned above)
Old 09-01-2002, 11:15 PM   #8 (permalink)
TN Track day addict
whp = hp at the wheels
where or when they use it is up to the manufacturer. as far as i know, thye've stopped using that figure for quite somet ime.
and yes it would not be the same as whp cuz they aint' the same thing!
My blog
Old 09-03-2002, 08:36 AM   #9 (permalink)
View fatredcircle's Photo Gallery
if bhp is ever used, its just a marketing termonology.
manufacturers, 90% of the time, messure th hp from the crank. Then, when it would go to press or to print, they just rate it as BHP...pretty insignificant and innacurate for the layman's sake.
two popular ways to measure hp is at the crank and at the wheels.
the crank hp is app. 30% more than what is measured at the wheels because of the loss in the drivetrain.
100 hp at the wheels = 130hp at the crank.
Nick
fatredcircle is offline   Reply With Quote
Old 09-03-2002, 03:33 PM   #10 (permalink)
View Consynx's Photo Gallery
i think they still use BHP when talking about Concept cars...
or cars to come(some now out)
i.e. before the 350Z was released, they were giving horsepower figures w/ bhp.
Consynx is offline   Reply With Quote
Old 09-06-2002, 12:05 AM   #11 (permalink)
View PeaZs's Photo Gallery
yea, new cars nowadays on ads, i see them say bhp
PeaZs is offline   Reply With Quote
