NEWBIE Q#3: wet sanding body - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition
Hardcore Tech and Competition Strictly HARDCORE tech info and questions and also autocross / racing discussion!
Old 09-03-2002, 11:11 PM   #1 (permalink)
operation boro thunder
View project trueno's Photo Gallery
to you body ppl, what grit sandpaper do you guys use when wet-sanding body? i dont want to scratch any paint off....just want to "clean" (or revive) the original paint
the car is white so you see black/grey shades of dirt residue stuck on it, want to get body nice and smooth again
THANK YOU :o
project trueno is offline   Reply With Quote
Old 09-04-2002, 01:43 AM   #2 (permalink)
The terrorist
View Xenon's Photo Gallery
2000 grit, it's as fine as paper.. The best way to do it is to get a bucket of water and a sponge, hold the sponge on top of wherever you're sanding and keep sqeezing the sponge and soaking it, don't press on the sand paper..
Don't freak out when you lose the shine It's normal, use the Maguier's Polish and then wax. Your paint will come out looking brand new...
Good luck..
My sexy AE92 http://members.cardomain.com/ababan
Xenon is offline   Reply With Quote
Old 09-04-2002, 08:26 AM   #3 (permalink)
Banned
View goodcookiedrift's Photo Gallery
theres different stages. and for each stage you use a different grit.
your not gonna get anything off by starting off with a 2000grit...you'll be lucky to break the clear coat.
start with a wet 320 grit and remove the ugly areas. sand lightly.
then move up to a wet 360 and sand lightly....you don't want to gouge the metal.
clean it with some silicon/wax remover (you can get it at body shops but its its pricy) Kleanol i think its called
prime it. then wet sand with a 600 grit till its smooth and even. rub your fingers over it.
let dry, spray with colour. wet sand with either a 600 or 1000 grit. you don't want to pull off the paint, you just want to keep it smooth. spray another coat and sand again. do this a total of three times bnut on the last, don't sand. then clear coat it. if you need to take off any imperfections, use a 2000 grit for that.
goodcookiedrift is offline   Reply With Quote
Old 09-04-2002, 11:29 AM   #4 (permalink)
1nzfe addict
View toymaniac's Photo Gallery
for ¨¨reviving the paint¨¨ i use a compound or on a white car i use vim yes vim!! its smoother than a compound.... then of course a good wax...
Toymaniac ADM. ClubEchoQuebec.com
toymaniac is offline   Reply With Quote
Old 09-06-2002, 01:19 AM   #5 (permalink)
View livininthefastlane's Photo Gallery
i dunno if you can get it in canada, but 3M also makes a wax/grease/prep cleaner and it too is expensive, but its well worth it....good luck!
livininthefastlane is offline   Reply With Quote
