Logical Reasoning on Toyota Engine Swaps... Your Thoughts? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition
Hardcore Tech and Competition Strictly HARDCORE tech info and questions and also autocross / racing discussion!
Old 06-27-2005, 03:04 AM   #1 (permalink)
The Mad Scientist
View Dr Tweak's Photo Gallery
Okay, here are a couple things that we know. The 3SGTE in the MR2 Turbo uses the E153 tranny, which is also used by the Camry (Solara) V6 (1MZFE). The 3SGTE also bolts up to the 5-speed in the I4 Camry (5SFE) and of course the Celica (5SFE or 3SGE). So would it be correct to assume then that, for example, you could take ANY MZ series engine, and bolt it to the 5-speed tranny found in an I4 Camry or Celica GT? (I don't need argument about the longevity of the tranny, the question is, WILL IT BOLT UP?).
And what about the 3VZFE in the earlier V6 Camrys? Can they also use the E153?
-Dr Tweak, Toyota engine swap wiring expert extraordinaire
Check out some of the swaps I've done at http://www.phoenixtuning.com/swaps.html
Dr Tweak is offline   Reply With Quote
Old 06-27-2005, 05:26 AM   #2 (permalink)
VeeZed
JetspeedCamry's Avatar
View JetspeedCamry's Photo Gallery
3VZFE can use E153, as does the 2VZFE, which i'm swapping in now.
1988 Toyota Camry 2VZ-FE E153
1972 Ford Mustang Sprint "F" 351C-2V 4SPD
1973 Ford Mustang Mach 1 "Q" 383C-4V FMX
JetspeedCamry is offline   Reply With Quote
Old 06-27-2005, 10:06 AM   #3 (permalink)
Toysrme's Avatar
View Toysrme's Photo Gallery
Cool
Yes they all will swap. Most of the fwd trans. will swap out with each other.
The shift linkage on the Celica / MR2 is on the wrong side of the tranmission, and have slightly different gearing.
Search the Camry forum for E153 swap. There have been two complete guides written on swapping them that cover everything in detail, and the minor differances.
AIM/Yahoo Toysrme257th
Now with Turbo!
