Installing an MSD BTM - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition
Hardcore Tech and Competition Strictly HARDCORE tech info and questions and also autocross / racing discussion!
Old 09-10-2002, 07:52 AM   #1 (permalink)
View Meisner's Photo Gallery
Has anyone ever installed an MSD Boost Timing Master unit? The one I have is the 5462...not the ignition system, just a timing retard module.
I have a 96 Camry 5S-FE with a turbo.
The car almost starts with it installed and then immediately dies. Obviously the MSD box doesn't like something. I am getting a spark (as seen with a timing light clamped on the ignition wire). It must be at the wrong time. So obviously the trigger is working.
Any ideas????? Help!!!!
Thanks
Steve
1996 Turbocharged Camry 5S-FE (4 cyl)
http://www.meisners.net/camry
Meisner is offline   Reply With Quote
Old 09-13-2002, 07:36 PM   #2 (permalink)
:thumbup: The answer...
I got it working. You have to install another MSD part; the 8910-EIS. This converts the trigger signal into something usable by the MSD 5462.
If you do this, be sure you get the 8910-EIS...if you try to use the 8910, it may not work. It must have the EIS suffix.
Steve
Old 09-14-2002, 12:08 AM   #3 (permalink)
View bondobondo's Photo Gallery
thanks steve, i was gonna suggest using a stock ignition system, but i have no idea how you are controlling fuel.
siu-sum loy-yun
nothing is forever
æ92.FF.pilot
bondobondo is offline   Reply With Quote
Old 09-14-2002, 05:29 AM   #4 (permalink)
Blazin...
SCEPTER300RR's Avatar
View SCEPTER300RR's Photo Gallery
oops im too late... heheee i was goin to tell u about the ignition transformer... oh well btw all toyotas will require that for msd!! for anyone who wants to know...
Neoscepter
SCEPTER300RR is offline   Reply With Quote
Old 09-14-2002, 05:45 AM   #5 (permalink)
Actually I think this module (the 8910-EIS) will allow any aftermarket ignition system to work with the Toyota ignition system.
It takes the trigger signal from the Toyota igniter, which is not strong enough to trigger an MSD 6-BTM, for example, and makes it a more significant pulse. I bet this stronger pulse will trigger any system.
Steve
