Opinions on T28 for 5sgte? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition
Hardcore Tech and Competition Strictly HARDCORE tech info and questions and also autocross / racing discussion!
Old 07-08-2005, 01:04 PM   #1 (permalink)
View MrDuece2's Photo Gallery
Question Opinions on T28 for 5sgte?
i am in the process of sourcing parts for a 5s-gte project (5s block, 3s head) and i just found a GREAT DEAL on a turbo kit for the gen3 3sge (which is the head im using) consisting of a T28 turbo.. i dont know much about this size, HP outcome, or how it would compare to a CT20b or T3/T4 - but i plan on boosting about 12psi daily (maybe an on-board switch to boost UP TO 17psi via Haltech's e6x [dual maps]). I'm staying FAIRLY stock except for the custom pistons needed for the stroker (and low comp. for turbo), standalone ECU, and other supporting mods such as injectors & fuel pump, exhaust.. any suggestions, opinions, info, etc?? i think im shooting for the 300hp range - maybe 350 if i get lucky, but just a basic set-up for now, and im wondering if this would be a good buy for my project? thanks guys...
MrDuece2 is offline   Reply With Quote
Old 07-08-2005, 08:57 PM   #2 (permalink)
Wild on the Flip Side
VooDoo's Avatar
View VooDoo's Photo Gallery
t28 might be a tad bit too small for a daily runner running 12psi. might be better to look for a T3, T3/T4, TD05 or a CT26.
Grupo Toyota
VooDoo is offline   Reply With Quote
Old 07-08-2005, 10:13 PM   #3 (permalink)
Toysrme's Avatar
View Toysrme's Photo Gallery
Cool
A t28 is far too small.
You'll have great low down performance with the FE head /cams, and the T25 turbine housing that is used. Unfortunately it'll choke quickly, probably a little more than half way through the rpm range and fall off drastically.
I assume you can't afford an expencive turbo...
A t3 / t4 hybrid using a t04e trim 46 compressor would work devinely. Probably would be spooling useable boost in the 3000rpm range, and large enough to pullthroguh the upper rpm range.
AIM/Yahoo Toysrme257th
Now with Turbo!
Old 07-09-2005, 11:49 AM   #4 (permalink)
would the T28 mate to a t25 or t3 bolt pattern? <reason i ask is b/c maybe i could still buy the manifold to get my kit started... probably a t25 manifold, right?
Old 07-09-2005, 12:06 PM   #5 (permalink)
Toysrme's Avatar
Cool
No. I'm telling you guys.... T28's are too small for stock Honda engine's. They choke on Honda's.
It'll be a death grip on a Toyota i4.:\
Now with Turbo!
Old 07-09-2005, 12:09 PM   #6 (permalink)
"I BUILD SLEEPERS"
Wraith's Avatar
View Wraith's Photo Gallery
Um no ... T28 isnt as bad as people think... If you do get a big a/r on the turbine side... If your hurting for money theres some nice Garretts that can be had for far less than you think...
heres a couple :
GT32
T3 60 trim
T3/T4E
Now before you guys think a T3 is too small theres alot of Tacoma guys with 2.4liters running a T28/T3 Hybrid turbos...
MySpace:
http://www.myspace.com/335453
Wraith is offline   Reply With Quote
Old 07-09-2005, 12:11 PM   #7 (permalink)
"I BUILD SLEEPERS"
Wraith's Avatar
This is true but you have to remember its a Honda engine those engines are built N/A and have a big cam profile... a T28 should be find, if you get the right a/r to go with it on a Toyota ...
MySpace:
Old 07-09-2005, 12:25 PM   #8 (permalink)
Toysrme's Avatar
Cool
t3 is a good size by itself. The buick's used modified t3's. And that's a big engine.
AFAIK, a T28 is a t25 turbine and some t3 sized compressor.
They're great on stock low end honda's because they have very, very fast responce (on the small engine) and power drops off quickly. That sounds like a negative, but it is a positive for them. With the "weaker" (and I use that loosely) engine's, they can't handle a good sized turbo that will give power through the high rpm band. It needs to drop off or you'll see rod material in the oil pan!
The Toyota's have a lot more low down grunt to get a turbo spooled, you might as well go for a bigger t3(or equiv) that will have a better top end performance, without sacrificing low end responce much at all.
Or you could do like Wraith said, and get a t28 with a big A/R on it. I didn't know they used a big T28 on the skyline.
Now with Turbo!
Old 07-09-2005, 02:14 PM   #9 (permalink)
so being that its basically a T25/T3 - i guess i could upgrade the T3 side to a larger super60 or something, right?? Wouldn't it be a T25 bolt pattern on the manifold then?? so i couldn't use a t3/t4.. ? i'd be buying the kit CHEAP so im trying to make sure i HAVE to rule it out completely before i pass this up - Blitz manifold, XSPower T28 (0miles), wastegate, and 1/2 of a downpipe including hoses, lines and fittings... $375 shipped!! what kind of upgrade could i do to the T28 then??
Old 07-09-2005, 03:01 PM   #10 (permalink)
Toysrme's Avatar
The t25 turbine side (t28) does not not use the t3 bolt pattern.
Yes you could upgrade the T28 side to any T3 wheel. My point is that you would be better off buying that sized t3 to begin with.
Now with Turbo!
Old 07-09-2005, 03:27 PM   #11 (permalink)
thanks. you guys have been a big help... obviously im not very knowledgable on the subject.
check out eBay item #7985774255 its a T04B V-Trim that bolts to a DSM (T25 manifold) - is that more like it??
