7A-FE Timming Problem - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition
Hardcore Tech and Competition Strictly HARDCORE tech info and questions and also autocross / racing discussion!
Old 07-08-2005, 11:35 PM   #1 (permalink)
View 94_Rolla_Guy's Photo Gallery
I just replaced my engine with a low Km used engine, After setting the timming to the factory 10deg before TDC for a test up the street and noticed pinging or knocking sound . i can adjust it out by running 5deg after TDC strangely the car runs reasonably well considering the timmings 15deg retarded?
BTW using all my old sensors from old engine and old distributor with new cap and rotor
my thoughts are:
1. wrong dampener, therefore timming marks are wrong; get the right dampener
2. messed up the distributor, getting too much advance; need new igniter or something
3. lean condition, therefore retarding the timing rectify's that; fix busted fuel system
Also can ignition timming effect an engine knock, lets say a wrist pin knock?????
Ah when she was in her glory, Not so nice anymore 358k 17years old her time is getting short ....
94_Rolla_Guy is offline   Reply With Quote
Old 07-09-2005, 07:25 AM   #2 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
check the cam timing against the tdc mark on the pulley
Old 07-09-2005, 07:51 AM   #3 (permalink)
Moving Forward
View Cyorke's Photo Gallery
Yeah it sounds like you may need to check the cam and crank gear timing. Not the distributor timing. Maybe you got something off a tooth and retarding the timing is compensating for it.
Chris
PLEASE DO NOT GET RID OF THE OLD TN AS WE KNOW IT.
Cyorke is offline   Reply With Quote
