What happened to these rod bearings (pics) - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition
Hardcore Tech and Competition Strictly HARDCORE tech info and questions and also autocross / racing discussion!
Old 07-12-2005, 03:52 AM   #1 (permalink)
View 94_Rolla_Guy's Photo Gallery
as some might know i just swapped a newer 7A-FE apparently not good enough......
the engine sat for 9 years before i bought it, immediately after initial startup i noticed a knock this is what i found... (cyl # 4 clutch side) just wondering WTF happened here the engine supposedly only has 37,000 km's on it
* * * * * also im gonna roll in a set of bearings tomorrow, do i need to replace the rod bolts and the main cap bolts?? * * * * *
thanks again everyone
Ah when she was in her glory, Not so nice anymore 358k 17years old her time is getting short ....
94_Rolla_Guy is offline   Reply With Quote
Old 07-12-2005, 05:45 PM   #2 (permalink)
Gameroom cash: $147537
If it seat for 9 years, chance is that the oil dry up can plugged the hole and bearing didn't get oil. Could also be rust. Check the shaft. probably the shaft got scratch too.
Old 07-12-2005, 08:42 PM   #3 (permalink)
homebuilt turbo guru
View 2001rolla's Photo Gallery
Sitting for 9 years the engine should have been rebuilt with at the least new bearings and seals. Sitting that long with any amount of oil in it other than machine is not a good idea. You should check the other bearings as well while you are at it and replace them all if you can afford it. I would also make certain that the oil galleys are not plugged.
Odds are the motor was pulled from the donor vehicle because of the damage you found but one can never tell.
2001rolla is offline   Reply With Quote
Old 07-12-2005, 09:15 PM   #4 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
those bearings didnt wind up like that over a couple seconds, that is liquid metal transfer, they almost welded themselves to the crank, most likely over storage the oil in the pump drained out and the pump lost its prime, you better check the entire motor even the cam journals in the head
Old 07-18-2005, 10:52 PM   #5 (permalink)
View D0UG's Photo Gallery
in the future
If an engine has been setting for 6 months or more without starting, it is a good practice to remove spark plugs, spray a rust release (WD40, Liquid Wrench, etc.) in the bores and let the engine sit overnight. Next day, crank the engine with the spark plugs out. This will help prevent breaking a ring that may have seized to the bore and will put oil back in all the bearings without them being loaded.
If the engine has been sitting for several years, drain the oil first. Moisture condensate will be at the bottom of the pan and you do not want to pick it up with the oil pump and mix it with the oil.
Like fredk said, these bearings are only part of the problem. The crankshaft is damaged too.
D0UG is offline   Reply With Quote
Old 07-18-2005, 11:02 PM   #6 (permalink)
Auto-Cross Addict
SmokingTires's Avatar
View SmokingTires's Photo Gallery
Looks like whoever put it together didn't lube the bearing properly when putting it together. That lube doesn't dry out, so 9 years shouldn't have done that.
'88 Toyota MR2 N/A - Sold
'99 Miata Sport - Sold
'85 Corolla GT-S - Sold
'02 MR2 Spyder - C-Stock car
SmokingTires is offline   Reply With Quote
