Displacement, pistons, and compression.... - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition
Hardcore Tech and Competition Strictly HARDCORE tech info and questions and also autocross / racing discussion!
Old 09-12-2002, 03:42 PM   #1 (permalink)
A Worthless Asset
Location: An island full of diseased monkeys an hour southeast of Houston
View 4DoorsofFury's Photo Gallery
Heres a nice topic for you guys. In what ways do a boaring (spelled right?) the engine and putting in bigger pistons affect compression. How do you crunch the numbers to get the desired compression?
...living life like both a speeding bullet and a calm breeze...
Scratch the 5S-FTE idea...I'm just a poor college student, but I can wait because in a few years ill be going 600 mph 100 feet above the ground.
4DoorsofFury is offline   Reply With Quote
Old 09-12-2002, 04:09 PM   #2 (permalink)
Turbo-Yota power
Jzs147-RR's Avatar
View Jzs147-RR's Photo Gallery
If you increase pistons size the compression stays the same but the volume of the combustion chamber is increased.To increse compression you need a piston that is not just bigger but taller or that has some sort of dome or surface that would lift in the center.Increasing piston size will increase power and so does increasing compression but with that comes the fact that the gas will not ignite like usual.Anyways i hope that anwsers some of the stuff you wanted to know.
5sfe powered turd ...
Jzs147-RR is offline   Reply With Quote
Old 09-12-2002, 04:41 PM   #3 (permalink)
Banned
View goodcookiedrift's Photo Gallery
or you could just shave your deck or cylinder head.
Nick
goodcookiedrift is offline   Reply With Quote
Old 09-13-2002, 03:36 PM   #4 (permalink)
A Worthless Asset
so compression changes only when the profile of the piston is indented or raised? kewl thnx for the info
Old 09-13-2002, 04:13 PM   #5 (permalink)
View Deep's Photo Gallery
Or deck height/stroke/bore are changed.
Deep is offline   Reply With Quote
