home grown octane booster?
I got this from a corvette forum, sounds a little nuts!!!
I recently read a thread on this forum about octane boosters so I thought this may be of interest to some.
FORMULA#1--TOLUENE
R+M/2.............114
COST.............$2:50/GAL.
MIXTURES WITH 92 OCTANE PREMIUM
10%..............................94.2 OCTANE
20%..............................96.4 OCTANE
30%..............................98.6 OCTANE
NOTES: Common ingredient in octane boosters in a can. 12-16 ounces will only raise octane 2-3 *points*,ie from 92 to 92.3 Often costs $ 3-5 for 12-16 ounces, when it can be purchased for less than $ 3/gal. at chemical supply houses or paint stores.
FORMULA#2----XYLENE
R+M/2....................117
COST....................$2:75/GAL.
10%.......................94.5 OCTANE
20%.......................97.0 OCTANE
30%...................... 99.5 OCTANE
Notes similar to toluene. 12-16 ounces will only raise octane 2-3 points ie 92 to 92.3 Usually mixed with toluene and advertised as race formula.
FORMULA #3--METHYL-TERTIARY-butyl-ether (MTBE)
R+M/2....................118
cost....................$3:50/gal.
10%.....................94.6 octane
20%.....................97.2 octane
30%.....................99.8 octane
Notes. oxygenate. very common in octane booster products. Has lower btu content than toluene or xylene,but oxygenate effect makes the gasoline burn better and produce more energy.
FORMULA #4--METHANOL OR ETHANOL
R+M/2..................101
Cost.......$0.60--$ 1:75/gal.
10%.....................94.3 OCTANE ( METHANOL )
10%.....................94.7 OCTANE (ETHANOL )
20%.....................NOT RECOMMENDED
Notes: Methanol is wood alcohol. Ethanol is grain alcohol and found in gasohol in 10% ratios. Both alcohols are mildly corrosive and will eat gas tank linings,rubber and aluminum if used in excessiive ratios. Main ingredient in gas dryers",combine with water.
FORMULA #5--ISOPROPYL ALCOHOL AND TERTIARY BUTYL ALCOHOL
R+M/2............................101
Cost.............................$0.60-$1:50/gal.
10%...............................94.5
30%.....................NOT RECOMMENDED
Notes: Similar to methanol/ethanol. isopropyl alcohol is simply rubbing alcohol.
SAMPLE MIXTURE
To make up your own octane booster, it is easiest to make up large batch and then bottle it up in dosage size uses.
Below is the basic formula of one of the popular octane booster products. To make eight 16 ounce bottles ( 128 oz=1 gal )
100 oz of toluene for octane boost
25 oz. of mineral spirits ( cleaning agent )
3 oz. of transmission fluid ( lubricating agent )
This product is advertised as octane booster with cleaning agent and lubricating agent. Diesel fuel or kerosene can be substituted for mineral spirits and light turbine oil can be substituted for transmission fluid. color can be added with petroleum dyes.
DISCLAIMER USE THIS IMFORMATION AT YOUR OWN RISK I ONLY POSTED THIS BECAUSE I THOUGH IT WOULD BE OF INTEREST TO MEMBERS OF THE FORUM.
D.P.
