electrical system quest - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition
Hardcore Tech and Competition Strictly HARDCORE tech info and questions and also autocross / racing discussion!
Old 07-29-2005, 03:13 AM   #1 (permalink)
Official Saipan Member
rogerman's Avatar
View rogerman's Photo Gallery
Question electrical system quest
What happens when you connect the + to the - and the - to the + on a battery? what damage does it do to the car? i know this sounds stupid in all but what fuses would blow if this was to happen?
1992 Hilux 4X4 22R-E Manual, LCE Headers, Epn cam, super 40, and revirginized.
rogerman is offline   Reply With Quote
Old 07-29-2005, 04:36 AM   #2 (permalink)
Where's my boomstick?
Tommy's Avatar
View Tommy's Photo Gallery
well, if you do it for more than like a split second, you risk blowing up the battery
Ive bridge the terminals before, not paying attention and dropping a screw driver or hitting it while undoing a terminal, you just get a big spark and a chunk on metal missing from your tool. doesnt seem like there is any serious damage with a quick tap, but i wouldnt do it more than that, or make it a habit.
My garage
1991 Nissan Maxima SE V6 5SPD - daily beater - Sold
1988 VW GTI 1.8l 16v - weekend beater - Blown engine
2005 Elantra GT sedan 5spd - Woo, no more beatup cars!
Tommy is offline   Reply With Quote
Old 07-29-2005, 11:43 AM   #3 (permalink)
Ricer Hunter
View flex-appeal's Photo Gallery
Like the man said, dont make it a habit - a quick tap is ok to see if the battery is dead.
In more technical terms what happens is this (i'll try not to get carried away with my explanation). Current flowing through a circuit is determined by volts/resistance - in a short circuit situation resistance is of course very very small, the voltage we know is 12V so therefore the current is 12 / Resistance . This ends up being a huge number and does damage somewhere if there are no fuses to blow etc.
For example, on a car battery if you short circuit it with a wire that has a resistance of 0.1 ohms (many wires could be even lower than that) then your current value is :
12/0.1 = 120 Amps
If there is no fuse then the wire will simply melt, burn, you can also start engine fires this way. Remember that this high value of current is only through the path with the low resistance , so your short circuit wire will melt but other car systems will probably be ok.
flex-appeal is offline   Reply With Quote
Old 07-29-2005, 10:25 PM   #4 (permalink)
rogerman's Avatar
alrite thanks for the replys guys i ended up blowin my Alternator,Efi and dome fuses replaced them and my truck was good to go
Old 07-30-2005, 12:54 PM   #5 (permalink)
View nkhhh's Photo Gallery
if i am not mistaken, the alternator would be the first to get burnt
nkhhh is offline   Reply With Quote
Old 07-30-2005, 08:36 PM   #6 (permalink)
rogerman's Avatar
yup your correct and its the hardest god damn fuse to remove
