4agze swap, engine is dieing (pics) - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition
Hardcore Tech and Competition Strictly HARDCORE tech info and questions and also autocross / racing discussion!
Old 07-30-2005, 07:48 AM   #1 (permalink)
View quigon's Photo Gallery
AE92 4agze swap, engine is dieing (pics)
Ok, so i finished my swap (4agze 3rd gen) recently but something really weird is happening out there. The engine has fuel and spark but the ecu won't keep the injectors working. The ecu is sending exactly two pulses per injectors while cranking and after that there is no more fuel going in the engine so it stalls. If anybody can help me I would appreciate so much, ive been working on this swap for the last month and i cant even get it to work ! Btw i used a stock bluetop (87.5+ with bigger rods), the stock pistons also and the bluetop head. Here are some pics if you would like to see how its made. Thank you !
quigon is offline   Reply With Quote
Old 07-30-2005, 01:40 PM   #2 (permalink)
3s-gte in a Camry?!?
white90dx's Avatar
Gameroom cash: $304575
The motor looks good....
Is the the correct ECU for the motor? How about injectors? The first thing that popped into my head is that the injectors might be the wrong impedance. Also, with the older toyota ECUs, they freak out and won't keep going if the ignitor is bad... Check out both of those things.
-Charlie
Old 07-30-2005, 01:43 PM   #3 (permalink)
Where's my boomstick?
Tommy's Avatar
View Tommy's Photo Gallery
im sure youve got this covered, but just thought id mention it to make sure.
Looks like youve got some intake piping missing, without it the car wont run...i know stupid stuff, but sometimes its the stupid stuff that fixes problems
My garage
1991 Nissan Maxima SE V6 5SPD - daily beater - Sold
1988 VW GTI 1.8l 16v - weekend beater - Blown engine
2005 Elantra GT sedan 5spd - Woo, no more beatup cars!
Tommy is offline   Reply With Quote
Old 07-30-2005, 04:44 PM   #4 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
be sure you have 12v going to the injectors at all times the key is in run or crank position
Old 07-30-2005, 06:55 PM   #5 (permalink)
theres no rad on the pic also, dont worry im not that dumb, actually the injectors surely are weird (they have 3.2 ohm impedance while they should be 2.9) for ecu, i got an ae101 computer with an ae92 harness, so i changed the 4 dizzy wire + another one that i dont remember. ANd yes i have 12 volt @ the injectors while cranking since they work twice before the engine dies. Heres a shot of the final product (dont worry bout those piping, its just to test the setup :P) btw i dont think its the igniter, since its a 7mgte igniter and that it was working into one of my friends car. the ecu tells me with a check engine when there is something wrong with the igniter. Btw, is anyone thinkin about a fried ecu ?
Old 07-31-2005, 05:05 PM   #6 (permalink)
white90dx's Avatar
Its the ignitor. Replace it with the correct one from your engine... Make sure all the correct feedback signals are there at the ECU... The ECU will turn off the injectors if it senses a problem with the ignition system to keep the car from backfiring, etc. (And give you the code you are getting!!!)
-Charlie
Old 08-04-2005, 09:23 PM   #7 (permalink)
View neil85AE86's Photo Gallery
agreed
-Charlie
I agree.
If not it could be the injectors, sometimes if injectors sit for a long time they need to be cleaned and flowed.
Neil
Uber D.I.Y. Zenki Turbo
Squirted since '03
1994 Tercel 2dr 5spd
2003 Mazda MPV LX
neil85AE86 is offline   Reply With Quote
Old 08-05-2005, 08:48 AM   #8 (permalink)
Gameroom cash: $147537
7MGTE? 6 cyl? Here is you extra 2 pulse.
Or maybe it doesn't care?
