High RPM question - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition
Hardcore Tech and Competition Strictly HARDCORE tech info and questions and also autocross / racing discussion!
Old 08-08-2005, 12:10 AM   #1 (permalink)
V6LE_CAMRY's Avatar
View V6LE_CAMRY's Photo Gallery
High RPM question
Hey i have a dum question here but just wanted to know if you race your engine to the max RPM's like once a day, will there be any chances of spinning a bearing even after the engine is warmed up and oiled well? I dont race my engine all the time but just whant to know.
V6LE_CAMRY is offline   Reply With Quote
Old 08-15-2005, 06:49 PM   #2 (permalink)
View JoeG's Photo Gallery
Probably not. I don't think I have ever done that to an unloaded engine. If it is a stock engine, you will get Valve bounce and missing. If however it is a tuned engine, your rods are the weak link. I might be a little concerned about the piston rings and cylinder walls. Of course it depends how long you hold it at max. Still, I don't think it is a good practice. It does nothing good.
JG
JoeG is offline   Reply With Quote
Old 08-18-2005, 07:06 AM   #3 (permalink)
The Other White Meat
terrastrife's Avatar
theres a rev limiter for a reason
toyota make the coolest sounding oens too
terrastrife is offline   Reply With Quote
Old 08-19-2005, 12:22 AM   #4 (permalink)
Rotor > Piston
powderblue91's Avatar
View powderblue91's Photo Gallery
its good to rev it up so carbon doesnt build up on teh internals. There's a redline for a reason, stuff starts to break when you rev above it.
I rev mine to redline at least every time i take it out and it's warmed up.
-Eric
1991 SV21 DX - The slow
1990 FC3S GXL - The go
powderblue91 is offline   Reply With Quote
Old 08-21-2005, 01:45 PM   #5 (permalink)
Now with even more BOOST
View QuadCamSix's Photo Gallery
Revving to redline is fine, under load. Free revving however can be very bad. If your sitting there in nutral even with the car warmed up and good clean oil, revving quickly to redline CAN damage your engine in some cases. The oil pump on a stock motor is a mechanical pump driven by the timing belt, chain, or even a cam. It is possible on some motors to rev the engine faster than the oil pump can build pressure to accomidate the perticular RPM. When this happens the rod berrings dont get enough pressure/flow. I have seen several hondas come into the shop with destroyed bottom ends because of kids free revving the motors. Redline is perectly safe under load or if its approached gradually.
Jim
MR2 V6 with an inordinate ammount of boost www.V6MR2.com
QuadCamSix is offline   Reply With Quote
