ECU O2 sensor MODS
Okay, lets try this again, evaporating post syndrome in effect
I have a 1zzfe and I want to run a 4 into 4, thats right, 4 into 4.
I have a OBX i got real cheap cuz they welded some up backwards, and since I have to get the tig out and scrounge some 304 tube to fix it, well why not have fun ;-)
The issue for me is this, physically, its no sweat 4 baby cats, 4 baby mufflers 4 sticks of 1-1/4 stainless tube, some flange work, and boom all done.
EXCEPT the O2 sensor, If I sample 1 cylinder, and let the ecu drive the other 3 essentially blind, that could be a big problem .
could I get three more stock ecu's and splice the inputs all common, except for the O2 sensor wires inputs which would be dediccated to each cyl and then use the outputs of the three new ones only for there own injector
does that sound feasible??
OR
could I just merge the 4 sensor outputs and feed the stock ECU a blended voltage ?
