limited slip suggestions needed - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition
Hardcore Tech and Competition Strictly HARDCORE tech info and questions and also autocross / racing discussion!
Old 08-15-2005, 12:49 AM   #1 (permalink)
N/A bites
Tercel GTS's Avatar
Putting an e153 from a 91 MR2 into a lightweight fwd car I'd like some knowledgeable suggestions on which lsd I would do best with. Also does anyone have one for sale?
I'll be using the car as secondary transportation with heaviest duty in solo2 races and a very rare 1/4 mile run.
雄のハヤブサ
Tercel GTS is offline   Reply With Quote
Old 08-15-2005, 01:29 AM   #2 (permalink)
The Mad Scientist
View Dr Tweak's Photo Gallery
If you can get a Quaife for it, go for that Just remember that you have it in a FWD, so don't get a 1.5 or 2 way LSD!
-Dr Tweak, Toyota engine swap wiring expert extraordinaire
Check out some of the swaps I've done at http://www.phoenixtuning.com/swaps.html
Dr Tweak is offline   Reply With Quote
Old 08-15-2005, 11:49 AM   #3 (permalink)
ECHO....Echo....echo....
BenG's Avatar
View BenG's Photo Gallery
I know that a 1 way diff is the best to put in FWD, but can you explain why??
BenG is offline   Reply With Quote
Old 08-15-2005, 11:09 PM   #4 (permalink)
The Mad Scientist
Because if the wheels lock together when braking in a corner, you'll understeer right off the road (and into a guardrail, river, mailman, etc...)
Old 08-16-2005, 11:37 PM   #5 (permalink)
N/A bites
Tercel GTS's Avatar
Did any V6 camry/lexus 5speeds come with lsd?
雄のハヤブサ
Old 08-18-2005, 07:06 AM   #6 (permalink)
The Other White Meat
terrastrife's Avatar
no, but you can fit mr2 ones.
terrastrife is offline   Reply With Quote
Old 08-21-2005, 04:02 PM   #7 (permalink)
N/A bites
Tercel GTS's Avatar
Which kind of lsd came factory in mk2 MR2's?
雄のハヤブサ
