Car won't start!!!!
Yesterday, I finally found the key to my DA Integra, so I decided to start it up, just to make sure it was still working (it was about a month or two ago). I turn it over and, no go. Stupid thing just keeps on turning.
OK so it's time to check for spark and fuel. I'm pretty sure fuel is present, as the spark plugs are wet when pulled. A friend told me to remove the spark plug / wire and look at the electrode while turning the engine over. No spark. So is it the plugs or the ignition? To figure that out, I pulled the old oscilloscope out of the closet and fired it up. I measured the electrode directly while turning it over and saw nothing. I believe you should see something in the order hundreds of volts if spark was present. There was some noise, but very low voltage.
I may have to dig a little deeper, maybe the coil is gone, or worse yet, the ECU??? Anybody ever had this problem? Anybody ever test a coil??
Thanks! I know this is not a 'Toyota' question, but I know you guys better than honda-tech or whatever.
Eric
94 JDM 4AGZE Corolla powered by www.sdsefi.com
00 Yellow Integra Type R #795
