Drawbacks to Intercoolers with >100% thermal efficency - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition
Hardcore Tech and Competition Strictly HARDCORE tech info and questions and also autocross / racing discussion!
Old 08-21-2005, 01:35 PM   #1 (permalink)
Now with even more BOOST
View QuadCamSix's Photo Gallery
Question Drawbacks to Intercoolers with >100% thermal efficency
Im in the prosses of building the duct work for my new intercooler. Due to the way the IC is mounted I could easily build a portion of the duct to feed dry ice onto the intecooler fins. The IC is mounted horizontally so the dry ice would work VERY well. I would only use this at the drag strip for short periods of time.
What, if any are the dangers of supercooling the air running through an intercooler? IE getting the intake charge colder than ambiant temps.
MR2 V6 with an inordinate ammount of boost www.V6MR2.com
QuadCamSix is offline   Reply With Quote
Old 08-23-2005, 10:53 AM   #2 (permalink)
Wild on the Flip Side
VooDoo's Avatar
View VooDoo's Photo Gallery
water damage because of condensation inside the pipes?
Grupo Toyota
VooDoo is offline   Reply With Quote
Old 08-23-2005, 12:45 PM   #3 (permalink)
The Other White Meat
terrastrife's Avatar
just use ice, not dry ice, and do it b4 line up, as they dont like water down the dragstrip.
go water injection.
edit: GOD DAMN NICE RIDE
terrastrife is offline   Reply With Quote
Old 08-23-2005, 01:22 PM   #4 (permalink)
one turbo is one too few
bgrieger's Avatar
Gameroom cash: $307350
View bgrieger's Photo Gallery
Not many, as long as you've tuned for that air density. If you have fuel tuning heading to the ragged edge without it, the additional air will make you go lean enough to go boom...not in a good way either.
If you tune for that dry ice setup, you will just run a little rich when you are on the streets...no different really than the air/water intercooler guys dumping ice in the reserviors to chill it below ambient.
Bob
Old 08-23-2005, 07:46 PM   #5 (permalink)
Well, the computer will compensate for the dense air because the MAS is after the intercooler. So, my only real problem is calculating the fuel ill need since im at 85% DS around 7 psi.
Time to install the bigger injectors and retune.
Thanks for the help guys.
