What could cause this? Coolant temp sender wigging out - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition
Hardcore Tech and Competition Strictly HARDCORE tech info and questions and also autocross / racing discussion!
Old 08-23-2005, 01:38 AM   #1 (permalink)
The Mad Scientist
View Dr Tweak's Photo Gallery
So, this 3SGTE swap is all but completed but there is one last issue that I'm dealing with. When I turn the key to on, the temp guage goes all the way up to the red. I thought maybe this was because the sensor was different, but they are the same between the 3SGTE and the '97 ST. I also took a temp sensor off a 4AGE and tapped a hole in the water housing and then installed it, but it does the exact same thing.
I know it's not a short in the wire because as soon as I unplug the connector the guage goes back down to cold.
Thoughts?
-Dr Tweak, Toyota engine swap wiring expert extraordinaire
Check out some of the swaps I've done at http://www.phoenixtuning.com/swaps.html
Dr Tweak is offline   Reply With Quote
Old 08-23-2005, 08:30 AM   #2 (permalink)
not actual size
brink's Avatar
View brink's Photo Gallery
You tested the sensor to see if it's bum?
-- Jonathan W.
http://fleshy.org.nz/
brink is offline   Reply With Quote
Old 08-23-2005, 04:19 PM   #3 (permalink)
The Mad Scientist
Yeah, its good. Anyway it's fixed now. It turns out that the second wire coming from the guage that goes right to the ground was disconnected.
-Doc
Old 06-16-2011, 03:13 PM   #4 (permalink)
View Bernight's Photo Gallery
I'm having the same problem where dose the second wire ground at? Any info youmightbe able to give me would be great.
Bernight is offline   Reply With Quote
Old 06-16-2011, 04:21 PM   #5 (permalink)
The Mad Scientist
What year and model? And make sure you are plugged into the correct sensor.
-Doc
Old 06-16-2011, 04:41 PM   #6 (permalink)
It's a 94 helix pickup 22re. If I disconnect the wire it still goes to hot. I have the wirering diagrams from a chiltons but it's not much help.
