I really need infor for ae101 gze swap - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition
Hardcore Tech and Competition Strictly HARDCORE tech info and questions and also autocross / racing discussion!
Old 08-28-2005, 12:35 AM   #1 (permalink)
View myoung84's Photo Gallery
I am swapping in an ae101 gze into my 89 gts and have a few questions. I have a 6 pin connector with heavy gauge wires in the cabin of my ae92. What do I do with all of these?
Also the 22? pin connect (not the ecu plug) what matches up to what from my 89 gts and my ae101 gze? I belive this is my gauges and what not.?
I really need the ae101 gze engine and cabin wiring. Any kind of help would be appreciated
Thanks,
myoung84 is offline   Reply With Quote
Old 08-28-2005, 11:30 PM   #2 (permalink)
Guitars and Cars
Chris Corolla S's Avatar
View Chris Corolla S's Photo Gallery
This might get a better response in the tech section: moved
Chris Corolla S is offline   Reply With Quote
Old 08-28-2005, 11:35 PM   #3 (permalink)
The Mad Scientist
View Dr Tweak's Photo Gallery
Thanks,
I can help you with any specific questions, but your post is very broad. Here is a thread that I wrote about engine swap wiring that should be helpful for you.
http://www.celicatech.com/forums/showthread.php?t=6359
-Dr Tweak, Toyota engine swap wiring expert extraordinaire
Check out some of the swaps I've done at http://www.phoenixtuning.com/swaps.html
Dr Tweak is offline   Reply With Quote
Old 08-29-2005, 12:15 PM   #4 (permalink)
That thread did help a little.
I need information such as the water temp sensor and oil presure wire from the ae101 body loom. Also how do I get the tach to work in my 89 corolla gts? What all do i need to send the blk/red to, it think its main efi or somthing, but I have alot of the same blk/red wire all eventually connected together?
Engine is from ae101 4agze and I have the whole clip.
Old 09-01-2005, 10:20 PM   #5 (permalink)
Wild on the Flip Side
VooDoo's Avatar
View VooDoo's Photo Gallery
you need to convert the signal from the DLI for your tach to read it. an MSD tach adapter could help.
Grupo Toyota
VooDoo is offline   Reply With Quote
Old 09-02-2005, 11:44 AM   #6 (permalink)
Where can i get an msd tach adaptor?
Old 09-02-2005, 05:59 PM   #7 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
http://store.summitracing.com/partde...=KeywordSearch
"Skoolin' the unlearned!"
Old 09-03-2005, 01:20 AM   #8 (permalink)
Will this make the stock tach in my gts work?
