Good thinking but, if you have them go to the ground they will drag as you try to drive on the lift.
Hmmmm.......
If this is a steet show car then I would go the easy way and just do an airbag suspension.
For a track car hmmmm........
If you could find something small enough maybe you could mount it between the body and controll arm. Rig it to extend the suspension. That would give you what you are lookng for. The trick there is making it so it dosen't interfere with the suspension during driving.
Hmmmm..........
Maybe a pivot system. Make the top a pivot, and use a quick pin to lock it in place.
Hell its easier to draw a picture(please excuse the crappieness of the pic).
