Toyota V6 cam specs needed for 5VZ-fe - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition
Hardcore Tech and Competition Strictly HARDCORE tech info and questions and also autocross / racing discussion!
Old 09-26-2005, 12:17 AM   #1 (permalink)
Now with even more BOOST
View QuadCamSix's Photo Gallery
I have been looking everywhere for the cam specs for my 3.4L V6
Lift, duration, etc....
If anybody can help I would be willing to buy you a beer or something LOL
Thanks
jmpersek@bulldog.unca.edu
MR2 V6 with an inordinate ammount of boost www.V6MR2.com
QuadCamSix is offline   Reply With Quote
Old 09-26-2005, 10:58 AM   #2 (permalink)
View lexusmech's Photo Gallery
I, most likely, can help. I work at a dealership and I'll try to remember to look on TIS to email you the specs. Please post the specific year, make and model your engine came from.
90' ES two-fity, balanced motor, head work, home built intake, lowered, wheels, window tint and some stereo upgrades, next...building my headers.
lexusmech is offline   Reply With Quote
Old 09-27-2005, 11:09 PM   #3 (permalink)
Im running a 5VZ-FE engine from a 1996 4 runner with all 98 electronics. The cams are most likely the same 96-98+ so the specs from any of those years should work.
If you can get that info, Ill list you on my website as a contributor LOL.
Thanks again,
Jim
Old 09-27-2005, 11:46 PM   #4 (permalink)
Offical TN Hillbilly
TcmaBoy's Avatar
View TcmaBoy's Photo Gallery
This is the best I can come up with. It is from the 1997 Tacoma FSM. It gives lobe height.
If this dosen't help drop URD a line. They have a lot of R&D in the 3.4.
http://www.urdusa.com/
TcmaBoy is offline   Reply With Quote
Old 09-29-2005, 10:40 AM   #5 (permalink)
Thanks for trying. Im really looking for duration so I can mess with the overlap. I could technically do it by trial and error on the dyno but the valve covers have to be pulled to change the cams relation to one another. Very costly and time consuming. Several people have recomended I contact URD. Ill shoot them an email.
Thanks again for your help.
Jim
Old 09-30-2005, 07:59 PM   #6 (permalink)
TcmaBoy's Avatar
That could be tough. Its not like the inline twin cam motors where you can use an adjustable pully. With the exaust being driven by the intake cam you could only adjsust by removing the cam and moving it a tooth. It seems like that would be a pretty radical change. Usualy you only adjust by a degree or two max. It seems like you would get that if not a little more per tooth. I suppose you could get a custom grind too. If you play with the tooth thing on the dyno let me know. I would like to see the result.
Old 10-01-2005, 09:09 PM   #7 (permalink)
1 tooth = ~3* on the cam BUT if I put an adustable cam gear on then I can advance or back off on that. Basically the cam timin Intake VS Exhaust will be off by three degrees but in relation to crank timing they would only be off by ~1.5 degrees. So, for example the intake would be retarded by 1.5* and the exhaust will be advanced by 1.5* With my raised redline and larger single turbo setup this could yeild HUGE results for verly little money.
Old 12-08-2005, 08:19 PM   #8 (permalink)
View mister2sc88's Photo Gallery
Jim
Did you ever get the specs on the 5VZ cams? Can you please post them, thanks!
mister2sc88 is offline   Reply With Quote
Old 02-14-2011, 03:45 PM   #9 (permalink)
SnowRocker88's Avatar
View SnowRocker88's Photo Gallery
Did anyone verify this? Basically I want to know, do the cams have 120 teeth in the mesh? (360/120=3* per tooth). I also will be looking at increasing my LSA and have yet to pull the valve cover on my engine.
SnowRocker88 is offline   Reply With Quote
Old 02-24-2011, 11:38 AM   #10 (permalink)
1MZ powered MR2
Jason.MZW20's Avatar
Gameroom cash: $226450
View Jason.MZW20's Photo Gallery
Not sure about the 5VZ-FE, but here's the 3VZ-FE's specs:
3VZ-FE
230 intake
230 exhaust
12 deg overlap
7.85mm intake lift (or .31")
7.6mm exhaust lift (or .30")
34mm intake valve
The 5VZ is likely more conservative than that.
1991 Toyota MR2 V6
Ported, rebuilt 3.0L 1MZ
Fully OBDII compliant and California smog legal
Jason.MZW20 is offline   Reply With Quote
Old 03-06-2011, 02:29 PM   #11 (permalink)
Lord of the Sith
Gothmog3VZ's Avatar
Gameroom cash: $391902
iTrader Score: 6 reviews
View Gothmog3VZ's Photo Gallery
3VZ-FE
230 intake
230 exhaust
12 deg overlap
34mm intake valve
5vz has cams tuned for more torque down low compared to the 3vz (which gives less peak torque, but has a nice flattish curve through out most of the range)
1993 Toyota Camry 3VZ 5-Speed
(Beige Beluga)
1989 Toyota MR2 3S-GTE 5-Speed (Din)
Need performance parts?
Shoot me a PM, I'll see what I can do
Gothmog3VZ is offline   Reply With Quote
