Water marks - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-28-2006, 07:44 AM   #1 (permalink)
View carloi's Photo Gallery
Australia Water marks
I need help guys. I have SERIOUS water marks on all my windows (they were there when I bought the car 2nd hand). I've tried glass cleaner, cut and polish wax, turpentine, industrial strength cleaner, and a lot of elbow grease, and they're still there! Didn't even look like it got lighter.
How the heck do I remove these marks!? They are giving me serious visibility problems.
Thanks.
carloi is offline   Reply With Quote
Old 07-28-2006, 09:39 PM   #2 (permalink)
View Deviant's Photo Gallery
Try a dedicated glass polish like Zaino or DP (Detailers Pride) Also read that someone used something called spot_x w good results
Deviant is offline   Reply With Quote
Old 07-28-2006, 10:00 PM   #3 (permalink)
Pb
Surfing TN via iPhone
Pb's Avatar
iTrader Score: 15 reviews
View Pb's Photo Gallery
What kind of polish were you using? Most any mild polish usually works for me.
Try Chrome polish. It always works good for me.
Vinegar usually works too.
Pb is offline   Reply With Quote
Old 07-29-2006, 11:25 PM   #4 (permalink)
Air Force MTI
1TallTaco's Avatar
View 1TallTaco's Photo Gallery
+1...try vinegar first, then the chrome polish. It should help. Post up a pic of the marks, maybe we have had the same type before and could offer more help.
1TallTaco is offline   Reply With Quote
Old 07-30-2006, 01:02 AM   #5 (permalink)
ok. will take a pic of it tomorrow.
So far, here's what I've done:
1. Eagle One auto one glass cleaner
2. Industrial Strength Cleaner (diluted at 1/10 when normal is 1/20 ratio)
3. Polyglaze Cut and Polish
4. Mineral Turpentine
5. Steel Power stainless steel cleaner
6. Vinegar, soaked around 5 minutes then rubbed vigorously
7. Turpentine (again)
In that order, and would you believe it.... the darn thing is still there.
The marks are kinda elevated and is rough to the touch. I suspect that it was parked under a tree during the rain and was left to dry. It's possibly minerals, scale, rust, and tree sap.
Any other ideas?
Old 07-30-2006, 01:23 AM   #6 (permalink)
Pow! Right in the Kisser!
Liter's Avatar
View Liter's Photo Gallery
Wha t we use for the new toyotas is steel wool...dont use any water or any cleaner with it. Just plain steel wool guranteed it will fix anything wrong you have on ur windows
Liter is offline   Reply With Quote
Old 07-30-2006, 07:17 AM   #7 (permalink)
steel wool? I suspect that the watermarks would definitely be gone by the time I'm through with it. However, what will I do with all the scratch marks?
Old 07-30-2006, 08:57 PM   #8 (permalink)
Pb
Pb's Avatar
You might want to try chome polish first. Use a buffer to apply it if you have access to one.
I hear that lots of people use steel wool with good results. But I have seen a few vehicles that had microscratches all over their glass from using steel wool. I recently detailed a Honda Civic where the owner used steel wool on the windows. The windows were ruined.
I was in a fender bender and my side window got scratched real bad. Check out how I was able to fix it with chome polish and a buffer.
That'll buff out
Old 07-31-2006, 07:19 AM   #9 (permalink)
Liter's Avatar
Nah you dont get scratchs with it....jsut make sure to not press to hard and use a fast circular motion
Old 07-31-2006, 07:55 AM   #10 (permalink)
Pb
Pb's Avatar
I'd be careful. Newer Toyotas and Hondas have softer glass than they used to.
Old 08-08-2006, 05:22 AM   #11 (permalink)
OKay, so I tried the metal polish and the marks are still there.
I really don't want to go into the steel wool thing. Is there any other ways I could get rid of these watermarks?
Still don't have a pic of it though cause you really can't see them in all the pics I've taken.
Old 08-08-2006, 04:51 PM   #12 (permalink)
Pb
Pb's Avatar
Are you using a buffer with firm foam pad?
Old 08-09-2006, 08:53 AM   #13 (permalink)
Liter's Avatar
Seriously dude you need to trust me on this one steel wool wont damage your windshield. You can also try using a razor blade if you dotn want to use steel woll
Old 08-09-2006, 11:39 AM   #14 (permalink)
Pb
Pb's Avatar
Chances are that it won't damage your glass if you use #0000 steel wool, but don't press too hard. Some window glass is softer than others.
It has mixed feelings on Autopia. http://autopia.org/forum/showthread....el+wool+damage
Old 08-11-2006, 05:57 AM   #15 (permalink)
ok. since I actually know theeved, I won't go through the steel wool route. Heck, if a professional detailer ended up with scratches, I'd probably do much worse. I will try the blade though and let you guys know.
I just applied the metal polish with a cloth and rubbed as hard as I could as I currently don't have a polisher.
The Free Mod Series: Part VII Cheap Water Injection Toysrme Camry & Solara Lounge 17 05-26-2010 02:13 PM
Echo 2000 check engine light Raistlin Yaris, Vitz and Echo Forum 19 03-26-2007 05:33 PM
Water marks left on seats. russ25nys 2nd Generation (2005+) 12 07-11-2006 03:34 PM
Water spill....carpool carwash asking $350 to fix png6778 General Discussion 10 05-04-2006 11:08 PM
