uneven paint... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-20-2006, 01:55 AM   #1 (permalink)
eeto........?
View _VVTi_'s Photo Gallery
uneven paint...
Earlier today I did some rust repair, then applied some paint to the previously rusted section.
However, after I sprayed on the paint, I noticed that the new layer of paint is abit higher in level compare to the original paint. Now do I take some ultra-fine sandpaper and sand it down so it is the same level?
I have to sand it no matter what because there was some paint running and dripping abit. So I'll have to sand it down anyhow.
But even after I sand it and re-paint it again, the paint will be slightly hight then the original so just wondering how would I fix this?
Thank you fellows!!
1994 Camry LE V6
Tokico blues + Vogtland / Depo headlamps / Clear bumper light / Silverstar / AEM CAI / Tenzo R Formula 10 + Kumho 215/50/17
_VVTi_ is offline   Reply With Quote
Old 08-20-2006, 10:12 AM   #2 (permalink)
eeto........?
morning bump!!
1994 Camry LE V6
Old 08-20-2006, 09:31 PM   #3 (permalink)
eeto........?
bumpity bump??
someone must be able to help...i know it!!
1994 Camry LE V6
Old 08-21-2006, 12:23 AM   #4 (permalink)
Pb
Surfing TN via iPhone
Pb's Avatar
iTrader Score: 15 reviews
View Pb's Photo Gallery
I doubt you can wet sand enough without sanding through the clear or base coat. You might have to sand it all the way down to metal and start over. Do primer, then a couple light base coats, then a clear coat. Then wet sand with 1500 and 2000 grit. Then polish to remove the sandpaper haze.
Pb is offline   Reply With Quote
Old 08-21-2006, 03:01 PM   #5 (permalink)
eeto........?
currently there is no clear coat on it, its only the base coat of paint. But the new paint sits higher then the original paint, so I was just wondering if i can wet sand down the base paint till it is flush with the original paint, or will I have to bring it down again to metal and primer it again?
1994 Camry LE V6
I'm new and I bring Tips on how to paint! TriumphGT6 General Discussion 11 02-15-2007 04:17 PM
Is your truck chipping? What color? boone 2nd Generation (2005+) 12 01-19-2006 11:42 AM
She's Got Holes 73sport Camry & Solara Lounge 7 12-07-2005 04:57 PM
Ready to paint my spoiler .where can i get paint to match and paint camry parts???? bigpeterock29 Camry & Solara Lounge 4 06-27-2005 09:57 AM
