Rims Peeling? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-24-2006, 08:19 PM   #1 (permalink)
Man of the Year
View haschen's Photo Gallery
Rims Peeling?
My Offroad rims are peeling around the bolts its like a "papery" plastic peel? i dont know how to explain it better. can this be fixed? How much does it cost for a re-chroming? thanks
haschen is offline   Reply With Quote
Old 08-24-2006, 09:39 PM   #2 (permalink)
silverxls's Avatar
View silverxls's Photo Gallery
alot of chrome and alum wheels are clearcoated for protection and shine. does it look like the chrome is peeling ? or a clear coat. clear coat would look kinda like plastic....but so would chrome if it were peeling...but the chrome wouldnt be clear...if it's clear coat, you could sand, then polish, being careful not to sand away the chrome, all evidence of peeling away and re-spray it yourself. re-chroming comes in lots of different quality and price ranges. if you did all the prep work yourself, sanding and removing any and all finishes and give them a perfect surface to work with, you could prob get them for around 50 each for good quality chrome......if they do all the labor it would add lots more...shop around...or check with any restoration shops in your area for advice on where to go...
silverxls is offline   Reply With Quote
Old 08-25-2006, 06:06 AM   #3 (permalink)
Man of the Year
it looks like a clear plastic...so clearcoat? what are the steps to fix this? thanks alot
Old 08-25-2006, 11:43 AM   #4 (permalink)
silverxls's Avatar
well, for one you could check around and see if there are any wheel repair shops in your area and get a quote on re-finishing them. they would do a total strip of the old clearcoat and then re-spray them. on a beemer i used to have with aftermarket chromes, i refinished a couple of them. i wasnt worried that they look perfect...just didnt want them to look like they were peeling. i scraped off all the loose clearcoat that would come off...then...CAREFULLY sanded with 800 the edges of where the clearcoat came off to feather it in some...then i polished the chrome and existing clearcoat to as good a finish as i could.... then washed and cleaned them real good, then i sprayed the bad areas with clearcoat... you can get it at most auto stores. i polished the areas to blend some...then waxed. the final results looked real good from a distance...but if you got down and looked closely you could tell.
Old 08-25-2006, 04:10 PM   #5 (permalink)
Man of the Year
cool thanks man
fix bent rims or get new ones? TRD_girl Archived Corolla threads 16 09-25-2007 10:16 AM
My expertise on rims and tires SpectraBlueCam Hardcore Tech and Competition 57 10-13-2006 11:54 PM
Rims are peeling? haschen General Discussion 10 08-27-2006 08:56 PM
Opinions needed on some rims. HELP PLZ. WreckedSt Celica Forum 3 10-04-2004 05:29 AM
