Paint is not as smooth after bumper repainted... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-18-2006, 03:24 PM   #1 (permalink)
View TitaniumSE's Photo Gallery
I got my '07 Camry rear bumper repainted (well, just the driver side) and they repainted it without taking it off. So, the paint on the body near the windows and the fenders isn't as smooth as the other side. I tried making it smooth by using some water and a MF cloth but it doesn't work....='[
TitaniumSE is offline   Reply With Quote
Old 11-18-2006, 04:26 PM   #2 (permalink)
View toyomoho's Photo Gallery
Is this orange peel? Might check with the repair shop to see what type of paint and painting system they used. Some paints can be buffed or polished with a little surfacing compound, others can’t. Check first as you may damage the paint or cut through the color coat into the primer or whatever is underneath.
Old 11-18-2006, 04:54 PM   #3 (permalink)
I will wash the car soon. Will Gold Class car wash get rid of it all if i scrub hard?
Old 11-18-2006, 05:35 PM   #4 (permalink)
2GR FTW
darksparkz's Avatar
View darksparkz's Photo Gallery
I'd recommend first claying it.
If that doesn't work, then try rubbing compound if it's really thick, otherwise move from an abrasive polish to a lighter one.
2007 Toyota Camry SE 2GR-FE
Retrofit TSX HID Projectors | TRD Lowering Springs | Smoked LED Tails | Custom Apexi WS2 Catback Exhaust | BlueBatMobile Eyelids| UR Front Strut Bar | UR 23mm Rear Sway Bar | K&N Short Ram Intake| Kenwood DNX8120 In-dash | Lexus IS350 18" Wheels | Toyota Japan JDM Vent Visors | IS-F Black Leather Shift Knob
Other cars: F20C (AP1) | 2JZ-GE (JCE10)
darksparkz is offline   Reply With Quote
Old 11-19-2006, 06:21 PM   #5 (permalink)
Where exactly can I get a clay bar off the shelf and how do I use it?
Old 11-20-2006, 09:21 AM   #6 (permalink)
Ron Jeremy's twin brother
screeber's Avatar
iTrader Score: 6 reviews
View screeber's Photo Gallery
IIRC, Pep Boys carries a claying package from Mothers or Meguiars for about 15 or 20. Or if you have detailing specialty store around you, they usually carry them.
For a "how to", check autopia or autogeek for a detailed review. Simply stated, you need a lubrication spray that you apply to a small surface on the vehicle, then run a flat surface of the clay bar over this area with mild/medium pressure. You should feel some resistance if it is picking up contaminants off of the surface, and as it works it is able to easily slide across the surface of the car. Just make sure you work in small areas, and make sure the surface you are working on is clean, and sufficiently lubricated.
check this out:
http://www.autogeek.net/clbaandlu.html
- disinterested
screeber is offline   Reply With Quote
Old 11-20-2006, 12:04 PM   #7 (permalink)
Pb
Surfing TN via iPhone
Pb's Avatar
iTrader Score: 15 reviews
View Pb's Photo Gallery
What do you mean by it's not smooth? Is the paint rough, like it has overspray, or is there actually small bumps in the paint, like Orange peel? Orange peel can't be fixed by any kind of wax, clay, or polish. Take it back to the body shop and tell them to wetsand it, like they should have done the first time. Overspray can be removed with a Clay bar kit, and polish.
Pb is offline   Reply With Quote
Old 11-20-2006, 06:26 PM   #8 (permalink)
I think it's overspray. Like when he was spraying the paint onto the bumper, I think some of it got on the body as well. If it's overspray, will a claybar be needed?
Old 11-20-2006, 08:37 PM   #9 (permalink)
2GR FTW
darksparkz's Avatar
Yes, claybar usually does remove overspray.
You can get them from most auto stores that sell some kinds of detailing supplies. They'll usually carry Meguiar's or Mothers Clay Bars.
Old 11-20-2006, 11:09 PM   #10 (permalink)
I'll see. Thanks guys!
Old 11-21-2006, 01:33 PM   #11 (permalink)
Pb
Pb's Avatar
Watch this video about claying. Clay Bar Paint Saving System
With overspray it can take several passes with the clay to get it all off. Just keep working it back and forth until it's all smooth. If the clay is sticking to the paint then you need to spray more lube. Don't worry if the lube makes a mess. It wipes right off. It's probably a good idea to Clay the whole car. Then wax afterwards. Or even better: polish and wax afterwards.
Old 11-21-2006, 07:35 PM   #12 (permalink)
^ Thanks a lot Pb. Well...is it possible to wash the car with Gold Class car wash, clay it with Mother's and then wax it with Gold Class wax? Oh yeah..polishing...I dunno how to do that. lol.
Old 11-25-2006, 02:11 AM   #13 (permalink)
'94 Camry V6/'02 Sequoia
View ToyotaJimD.'s Photo Gallery
Pb must be on vacation, but yes, you can do that... mixing and matching brands like that is just fine.
But you'd want to avoid waxing the new paint, unless it's fully cured already. So you might just want to address your overspray problem and then wait 30-60 days (or whatever the paint shop recommend) and re-do the whole car at that time.
ToyotaJimD. is offline   Reply With Quote
Old 11-25-2006, 04:06 PM   #14 (permalink)
So just wash the car, clay it, wait 30-60 days,wash it again, and then wax it?
Old 11-25-2006, 06:13 PM   #15 (permalink)
I guess I should explain a little better...
Indeed, you should wash the car, or at least use a detailer before claying.
Go ahead and clay the overspray on the area of the original paint that needs claying and follow with wax. Now this is assuming it's overspray and not just a poor job of blending-in.
If you want to clay the whole car, except for the new paint, go ahead.
Your only unknown is if you need to wait for the new paint to cure -- meaning you don't want to wax before it's cured, and that's usually 30-60 or even 90 days. Sometimes they have the technology to cure it while it's at the shop, but you'll want to ask how long to wait before you wax. When you're ready to wax the new paint, that's when I'd clay it -- just before.
Just to clarify... You should wax after claying -- and allow time for that -- as clay will remove any protection (previous applications of wax or sealants or whatever) and leave the paint unprotected.
Whether you clay part of the car or the whole car is pretty much up to you.
If you have any doubts about this all... take it back to the dealer and have them fix it. If you have any doubts about the dealer's skills, take it to a trusted body shop and/or detailer (get trusted referrals) and make an informed decision on what to do.
Custom Tercel Body Kit TeRcElIcA Tercel, Paseo, Starlet, and Sera Forum 19 12-30-2009 01:49 AM
OPPS!!! Need new rear bumper! jeep2tacoma 2nd Generation (2005+) 17 07-28-2006 08:38 AM
Ready to paint my spoiler .where can i get paint to match and paint camry parts???? bigpeterock29 Camry & Solara Lounge 4 06-27-2005 09:57 AM
Where can i get paint to match my camry,so i can paint new factory spoiler? bigpeterock29 Camry & Solara Lounge 4 06-19-2005 03:56 PM
