polishing. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-06-2006, 09:56 PM   #1 (permalink)
View samcollett's Photo Gallery
polishing.
this might sound like a really newbish question to some of you more experienced detailers, but is polishing by hand a bad idea? i'm planning some serious paint repair(i have a scratch down to the metal on my tailgate) this weekend, but i don't own a buffer. i just have polishing compound and pads. i've heard that doing it by hand will just make things worse. true? thanks.
samcollett is offline   Reply With Quote
Old 12-06-2006, 11:01 PM   #2 (permalink)
2GR FTW
darksparkz's Avatar
View darksparkz's Photo Gallery
It's not "bad", but just much much harder. You'd need a lot of elbow power and repetition to be able to show results. It's just going to be harder, wouldn't really harm the paint unless you do it completely incorrectly.
I tried using rubbing compound to remove overspray that has been on for a year on a car, and it took quite a bit of effort just to remove that.
2007 Toyota Camry SE 2GR-FE
Retrofit TSX HID Projectors | TRD Lowering Springs | Smoked LED Tails | Custom Apexi WS2 Catback Exhaust | BlueBatMobile Eyelids| UR Front Strut Bar | UR 23mm Rear Sway Bar | K&N Short Ram Intake| Kenwood DNX8120 In-dash | Lexus IS350 18" Wheels | Toyota Japan JDM Vent Visors | IS-F Black Leather Shift Knob
Other cars: F20C (AP1) | 2JZ-GE (JCE10)
darksparkz is offline   Reply With Quote
Old 12-06-2006, 11:17 PM   #3 (permalink)
View toyomoho's Photo Gallery
Hand rubbing just takes longer. If done correctly, it should be much safer then a power buffer. Check the link below and do a TN search:
http://www.toyotanation.com/forum/showthread.php?t=48690
Old 12-07-2006, 06:25 PM   #4 (permalink)
link no worky. thanks, but i already searched. i'm asking becuase i've tried this on previous scratches and, using turtlewax polishing compound and an applicator pad, i scratched my clearcoat even more.
Old 12-07-2006, 10:16 PM   #5 (permalink)
2GR FTW
darksparkz's Avatar
Fixed Link: http://toyotanation.com/forum/t48690.html
http://autopia-carcare.com/inf-paint-polish-clinic.html
From using an more abrasive polishing compound, you will first notice a bunch of marks on it. That's why your supposed to move on to a less abrsive polish to try to polish out the previous marks left on by the more abrasive ones.
Old 12-07-2006, 10:30 PM   #6 (permalink)
'94 Camry V6/'02 Sequoia
View ToyotaJimD.'s Photo Gallery
An alternative would be to use a scratch remover product, followed by a polish (and wax) or cleaner wax..
ToyotaJimD. is offline   Reply With Quote
Old 12-08-2006, 11:54 PM   #7 (permalink)
Pb
Surfing TN via iPhone
Pb's Avatar
iTrader Score: 15 reviews
View Pb's Photo Gallery
If you can see metal then there's no way you can polish out the scratch. You need some touchup paint, and then let it dry for a day, then wetsand and polish it smooth. I've got a little info on fixing a paint chip in my CarDomain. IMO using an orbital buffer is very safe and will yield much better results than polishing by hand. Rotary buffers are the ones you have to be careful with.
Pb is offline   Reply With Quote
Old 12-09-2006, 07:50 PM   #8 (permalink)
i plan on applying the touch up paint first, and then sanding, and then polishing out the sanding marring. that's what i'm worried about though, because in the past i've not had good results with polishing by hand. i checked out your cardomain page about scratch removal too pb. good stuff.
Old 12-10-2006, 02:06 AM   #9 (permalink)
Sorry, I didn't catch "down to the metal."
You could also try a product like Langka ... check it out at www.langka.com ... that smoothens the paint after you touch-up.
Polishing parts... :p ovrrdrive 89-95 Toyota Pickup/Hilux 9 05-30-2006 09:05 PM
Klasse...polishing question Goatkey 2nd Generation (2005+) 16 05-27-2006 10:09 AM
Rust protection and Polishing a new car watsigdunk 1st Generation (2003-2008) 2 12-08-2004 07:53 AM
porting and polishing UK_MRV6 Camry & Solara Lounge 19 11-18-2004 05:58 PM
Polishing Compound deadzone1003 General Discussion 5 09-06-2004 02:17 PM
