How effective is WD-40 on tar? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-13-2006, 10:23 PM   #1 (permalink)
View TitaniumSE's Photo Gallery
I would like to spend $3.99 on Tarminator, but I'm leaning towards WD-40 because it has many more uses than just taking tar out. It's $2.00 at Target. So..has anyone ever used this on tar? Is gas effective too?
TitaniumSE is offline   Reply With Quote
Old 12-14-2006, 02:08 AM   #2 (permalink)
'94 Camry V6/'02 Sequoia
View ToyotaJimD.'s Photo Gallery
Good question... WD-40 might work okay, but it might discolor sensitive surfaces, too.
I don't think I'd use gas.
If you're talking body paint, just get some Mineral Spirits or Gum Turpentine.
Whatever you use, test in an inconspicuous area if you're unsure.
Wax afterwards.
ToyotaJimD. is offline   Reply With Quote
Old 12-14-2006, 06:04 PM   #3 (permalink)
I'm gonna take tar off of the underbody. Near the wheel wells.
Old 12-14-2006, 06:26 PM   #4 (permalink)
Not a Pre-runner
Twisted Sid's Avatar
Gameroom cash: $384300
View Twisted Sid's Photo Gallery
turtlewax bug and tar remover this shit works awesome. its in a yellow spray can. took tar and road grime off my old rims and paint after it had been on there for a year and and a half.
'94 Pickup: Std Cab, 22RE, 5spd, 2wd
Front: Total Chaos Uniball Kit, Fox 8''Coilovers, Custom Engine Cage, Hannemann Fenders,
REAR: Deaver F67 Leafs, Fox 14''Shocks, Custom Bed Cage, Glassworks Bedsides, Tacoma E-locker Axle 4:88 31x10.5 BFG AT Tires
Twisted Sid is online now   Reply With Quote
Old 12-14-2006, 06:48 PM   #5 (permalink)
View thoughthard's Photo Gallery
I have had good results using car wax on tar areas...
thoughthard is offline   Reply With Quote
Old 12-14-2006, 09:43 PM   #6 (permalink)
^ You mean using wax to remove tar? WTF?!?!?
Old 12-14-2006, 11:46 PM   #7 (permalink)
View toyomoho's Photo Gallery
WD-40 is mostly kerosene or something similar. This is one reason its rust protection does not last as long as something like LPS. It also has a tendency to stain plastic and painted surfaces.
Old 12-15-2006, 12:56 AM   #8 (permalink)
A cleaner wax can remove light tar, but if you've got stuck-on clumps, you need a solvent.
Always test in an inconspicuous area -- even bug and tar removers aren't always ideal for all surfaces -- read the fine print.
Several applications may be necessary.
Also, watch the expletives... this is a family-oritented forum (I think).
Old 12-16-2006, 12:50 AM   #9 (permalink)
Not a Pre-runner
right, but you know in the last 3 years i have been on this forum i havent seen very many familes on here. and if the word shit offends you, this might not be the right forum for you.
Old 12-16-2006, 11:26 AM   #10 (permalink)
LIFER
CDUFF777's Avatar
View CDUFF777's Photo Gallery
key word here is underbody - I would go for the wd-40 method, I have sprayed the entire underbody of my truck with wd-40 prior to winter driving - it works well, you may get some burn off on the exaust components but that won't last long.
1 JDM FROM HERE IN JAPAN
CDUFF777 is offline   Reply With Quote
Old 12-16-2006, 04:59 PM   #11 (permalink)
Try Simple Green on the tar.
Old 12-16-2006, 11:10 PM   #12 (permalink)
silverxls's Avatar
View silverxls's Photo Gallery
i'll second the turtle wax tar and bug remover.... this has worked very well for me. i've used wd40 many many times for at least the last 30 years, and it works better than most things, like wax or cleaners. i remember trying simple green. it was a good cleaner on oily stuff, but not on tar. just remember after using the turtle wax or wd40, you will need to wax.
silverxls is offline   Reply With Quote
Old 01-09-2007, 09:05 PM   #13 (permalink)
Mule's Avatar
View Mule's Photo Gallery
I have used WD40 several times...worked well
Mule is offline   Reply With Quote
Old 01-13-2007, 07:13 PM   #14 (permalink)
TN's Resident Car Whore!
dna59's Avatar
View dna59's Photo Gallery
I guess for the underbody it wouldn't hurt using it. But you would definately not wanna use it on paint and shit.
http://www.xclusive.bz
How to remove road tar from truck!! scalder 2nd Generation (2005+) 14 10-15-2006 09:39 PM
Got road tar on my new Camry...I am pissed..please help remove vinniemak 5th & 6th Generation (2002-2006 & 2007-2011) 16 08-07-2006 07:51 AM
Retrofitting Other Car Model Wheels With Gen3 (5x114.3) A2brb 3rd & 4th Generation (1992–1996 & 1997–2001) 13 11-11-2005 09:55 PM
