I'm not sure what that surface is, but if it's a simulated wood, then Plastic polish would have to be used very carefully unless there's a pretty good clearcoat on it or you may risk wearing through the "printed" pattern. Look at it with a magnifying glass and see if you can see a dot pattern, which would indicate it's "printed."
If it's real wood with a laquer or other clear coating, start with a cleaner wax, a scratch remover, or perhaps even Plastic Polish... either one should work depending on the coating.
Again, I'm not sure of the surface, but some experimentation in an inconspicuous area may be called for unless you get some better suggestions.
