I did a search, but didn't find many post about this! I decided to removed the pin stripe on my 11 y/o coupe. I've done it before on newer vehicles and it was a piece of cake, since they weren't baked on so, (hair dryer, and they came right off)! I figured the coupe wouldn't be so easy as there so old! There's a removal wheel that u attach to a drill, i'm told, and thats suppose to work, but my paint is 11 y/o too didn't want to take the chance with one, so here's what I did yesterday!
I first sprayed this Aircraft adhesive remover along the entire stripe, and let it soak in a few minutes
I then used a hair dryer, to heat up the stripe in 2-3" in sections, and used my "thumb nail" to scrape off the heated area. I did this on the entire front fender, then reapplied the 3M stuff again to remove the glue thats left behind. Wiped it down with a damp cloth, then used the Meguiras cleaner wax for a final cleaning! Did the same all around the car, fender,door, Qt panel....Here's the result...took about an hour +....Only problem! My thumb is alittle sore and I have a bunch of gold stripe under my finger nail!!
I'm glad I removed it! I think is looks better without the stripe. Thinking about removing the rear emblems too...Not sure!!?..Comments are appreciated!
(MOD'S maybe I started this in the wrong section! Feel free to move it if you choose!!)
