Swirls after washing - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-23-2007, 10:42 PM   #1 (permalink)
Tacoma Noob
cincybungle's Avatar
View cincybungle's Photo Gallery
I washed my truck last weekend the same way I always do. To help judge what I did wrong, I'll go through step by step how I wash and dry it. First I got out the microfiber wash mitt ( the new kind with the dangly microfiber things which could be the problem i'm thinking) Then I dumped Meguiar's NXT wash in a bucket and filled it with water and another bucket with just water for rinsing. Then I hosed the truck down and started scrubbing after a good rinsing. I moved the mitt in a side to side motion from top to bottom avoiding circular motions. Every time I washed a section (approx. 4' X 4') I rinsed the put the mitt in the rinse bucket and rinsed afterwards too. Once I was done washing, I used a Water blade to remove most of the water and used 4 or 5 microfiber cloths to get what was left. Are these techniques outdated now, or did I just do something wrong? I took extreme car to ensure there wasn't any debris on any of the microfiber, but my main concern is the new mitt. let me know what you pros think! Thanks for any advice!
'07 V6 Double Cab Tacoma 4X4 TRD Off-Road Indigo Ink
cincybungle is offline   Reply With Quote
Old 04-24-2007, 01:42 AM   #2 (permalink)
'94 Camry V6/'02 Sequoia
View ToyotaJimD.'s Photo Gallery
If you didn't wash the mitt first, that may be the problem.
I'm not keen on the water blades.
If your microfiber towels weren't clean, that may be part of the problem too.
Or also, if you've used a product with fillers in the past, they may have finally washed off and exposed spiderwebbing previously induced and subsequently covered-up... and just now uncoverd.
1994 Camry V6 XLE - Cashmere Beige
2002 Sequoia - White
ToyotaJimD. is offline   Reply With Quote
Old 04-24-2007, 03:26 AM   #3 (permalink)
Pb
Surfing TN via iPhone
Pb's Avatar
iTrader Score: 15 reviews
View Pb's Photo Gallery
I don't like microfiber when it comes to washing. Microfiber holds dirt. Holding dirt is not good when it comes to washing. You want the mitt to release the dirt when you rinse it out in the bucket. Rubbing a dirty mitt across your paint will cause swirls.
What do you mean by "scrubbing". Sounds kinda rough.
First I use a foam gun and soak the whole truck with soapy water. This loosens dirt and softens up bugs, so you don't have to rub so hard to get the bugs off. Rubbing hard will make swirls.
It's pretty much impossible to do a totally swirl free wash, but you can certainly minimize swirls. Even with a perfect washing technique there will still be some swirls that will accumulate over time. But this is why we have polish.
Pb is offline   Reply With Quote
Old 04-24-2007, 11:10 AM   #4 (permalink)
View stuts's Photo Gallery
Canada
you need to use a SHEEPSKIN MITT
http://www.canadiantire.ca/browse/pr...=1177430913007
ALSO
try getting a bucket like this
http://www.canadiantire.ca/browse/pr...=1177430912971
stuts is offline   Reply With Quote
Locked in park after washing jessenelson37 2nd Generation (2005+) 7 01-29-2007 08:19 AM
Washing Engine Maticuno 2nd Generation (2005+) 12 07-01-2006 06:40 PM
Now I'm washing with warm (or hot) water Dana_15 Detailing & Car Care 9 04-16-2006 05:46 AM
HELP: Pressure washing and engine bays... zyg0te General Discussion 2 03-20-2004 05:13 PM
Is there a special way of washing the tailight b4 spraying Hot_Sauce_8 Camry & Solara Lounge 1 07-25-2002 09:14 PM
