Originally Posted by DanEz_yoda
Gents,
I just bought some 2005 16" TRD off road tacoma alloy wheels used and when they came, the wheels were shipped dirty and the box rubbed against the finish and scuffed it pretty good by the time they got to me.
These are not bushed aluminum wheels but the alloys that appear to be painted metalic silver in color. The scuffs didn't chew all the way thorough the finish but they are noticable.
When I wipe them with windex, they went away but quickly came back when the windex dried.
I'm thinkin that I can wetsand with the 1500 grit and knock off the high spots then switch to a hand polish/elbow grease to put a shine on them and finish with Klass AIO.
I don't have a DA polisher so its' going to have to be done by hand and probably by something I can get local.
Looks like Mcguiers and 3M polishes are available, which would yaull recommend.
Any other suggestions?
Sounds like scratches in clear coat, but I am guessing.
I wouldn't wet sand...at least not initially. You don't know how much paint (if it is indeed paint) you have to work with. If they are polished aluminum and clearcoated, again, you still don't want to take off too much material.
Start out with the mildest abrasive you have in your arsenal first. Scratch-X is a diminishing abrasive and will go fairly deep initially, then smooth out. I've seen it put sandpaper-like scratches in black paint. If possible, try an inconspicuos area first and make sure you are happy with the results.
You can always go more abrasive later, if you need to, but if you start out with too much there's no going back.
I will be an official vendor on this site shortly and can make product recommendations then, but in the interim...be careful!
EDIT: If you can provide pictures, that would be great.
