buffer pads - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-08-2007, 12:19 AM   #1 (permalink)
It's Soo Hoo like Yoo Hoo
MrSo0h0o's Avatar
Gameroom cash: $303505
View MrSo0h0o's Photo Gallery
buffer pads
hey guys, my dad has an older orbital buffer that i plan to use tmrw.. he only has one pad.. question is, does autozone carry extra pads that i need for polish, wax and buff off? or do i need to order them specifically for the unit im using?
MrSo0h0o is offline   Reply With Quote
Old 09-08-2007, 12:51 AM   #2 (permalink)
touringcamry's Avatar
Gameroom cash: $550225
Is that the one that just spins the pad around?
I think those typically use 8" pads but I don't recall seeing them at Autozone. However, the Autozone here doesn't have 5W-20 motor oil either.
2007 Camry 2.4L 5M
Old 09-08-2007, 07:54 AM   #3 (permalink)
MrSo0h0o's Avatar
it looks like this:
and theres a bonnet pad on it like this:
Old 09-08-2007, 08:03 AM   #4 (permalink)
MrSo0h0o's Avatar
ok just looked at the autozone website and they carry these:
http://www.autozone.com/R,NONAPP848/...ductDetail.htm
http://www.autozone.com/R,NONAPP850/...ductDetail.htm
http://www.autozone.com/R,NONAPP851/...ductDetail.htm
one is microfiber, second is terry cloth, third looks to be like lambs wool.. which should i use? im gonna assume microfiber
Old 09-08-2007, 08:35 PM   #5 (permalink)
I usually use foam pads with my PorterCable buffer so I'm not very sure.
My guess is to use the microfibers because the wool pads are for cutting.
2007 Camry 2.4L 5M
Old 09-08-2007, 09:24 PM   #6 (permalink)
Pb
Surfing TN via iPhone
Pb's Avatar
iTrader Score: 15 reviews
View Pb's Photo Gallery
This is probably obvious, but I'll mention it anyway. Those kind of buffers are meant to have bonnets on the pad all the time. Don't put the bare pad directly on the paint, like you do with a porter cable buffer.
Pb is offline   Reply With Quote
Old 09-09-2007, 01:08 AM   #7 (permalink)
MrSo0h0o's Avatar
yea i know that, im just not sure what bonnet to use? the wool, microfiber or terry cloth? like i said above, im assuming the microfiber?
Old 09-09-2007, 07:42 PM   #8 (permalink)
Pb
Pb's Avatar
Get rid of the terry cloth.
Can you find a foam bonnet? They're harder to find. A foam bonnet would be the best for polishing.
You can use the wool while polishing, but be careful at first. Some wool can cause swirls. Give it a small try first.
Use a soft Microfiber for removing the polish. But it should also be safe to use while applying wax and polish.
I usually just apply wax by hand.
Old 09-09-2007, 09:52 PM   #9 (permalink)
MrSo0h0o's Avatar
thanks Pb i will check into foam bonnets.. im planning to detail either this coming thurs or next tues.. so if anything i can always order some online.. recommend any places?
Old 09-10-2007, 08:33 AM   #10 (permalink)
http://www.autopia-carcare.com/
http://www.autogeek.net/
2007 Camry 2.4L 5M
Old 09-12-2007, 11:57 AM   #11 (permalink)
Rapid Roy's Avatar
View Rapid Roy's Photo Gallery
Originally Posted by MrSo0h0o
it looks like this:
I've got one of those types sitting in my garage too. Is it better then nothing, or is nothing better?
Rapid Roy is offline   Reply With Quote
Old 09-13-2007, 02:13 AM   #12 (permalink)
Pb
Pb's Avatar
They're pretty weak when it comes to polishing. IMO, they're just fast wax applicators.
It takes real speed and power to effectively polish.
But I guess they're better than doing it by hand, maybe.
Old 09-13-2007, 06:31 AM   #13 (permalink)
it is what it is
akira751's Avatar
View akira751's Photo Gallery
Gen6
I got one free and its sitting in the basement, I'm scared to use it
07 Camry SE V6, Nav Mag Grey,18" Nex-0 gun metal, Trd Springs,K&N Typhoon Intake
http://www.cardomain.com/ride/2475669
akira751 is offline   Reply With Quote
Old 09-13-2007, 01:07 PM   #14 (permalink)
Rapid Roy's Avatar
I've got an old van sitting in the driveway. I'll use the foam bonnet and see if I can polish it up in a small area.
Old 09-13-2007, 02:41 PM   #15 (permalink)
PolishAndWax's Avatar
View PolishAndWax's Photo Gallery
Depending on the blend, wool can be pretty aggressive and will generally leave a scratch pattern. This doesn't make wool bad; you just need to consider it's intended application, like polishing to remove heavy oxidation, color sanding scratches or heavy scratches that just seem to be taking too long to remove with foam.
Also, the scratch pattern left by wool will be pretty subtle, depending on the polish and application method. It may be harder to see on lighter finishes.
I only break out the wool when I need the 'big guns' and then I finish with foam.
PolishAndWax is offline   Reply With Quote
Are these good rotors to get? cman2000 Camry & Solara Lounge 32 11-24-2007 01:32 AM
Recall, my new ball joints and I did my front brake pads, I'm happy! Thundra 1st Generation (2000–2006) 1 04-22-2007 09:12 AM
Can't find replacement brake pads for XRunner kpagel 2nd Generation (2005+) 6 12-11-2005 04:49 PM
Should I do this or just change the pads? abimanyu Archived Corolla threads 2 09-27-2005 07:48 AM
Anti-squeal on brake pads... 97&02camryleI4 Camry & Solara Lounge 10 06-25-2004 12:01 AM
