what's next? (pic included) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-30-2008, 05:20 PM   #1 (permalink)
View nobitanobi's Photo Gallery
I have owned my Gen4 for 5-6 years now. I do maintenance on the car once a while. Today I attempted to clean a pot of coffee under the front passenger seat (previous owner did it )
Before:
After:
Obviously alot cleaner than before but still not perfect.
I used Little Green and some hard scrubbing
1-2 hrs
What's the next step?
Thanks
nobitanobi is offline   Reply With Quote
Old 03-30-2008, 11:01 PM   #2 (permalink)
Pb
Surfing TN via iPhone
Pb's Avatar
iTrader Score: 15 reviews
View Pb's Photo Gallery
What chemical cleaner are you puting in the Little Green? How long are you letting it sit before sucking it up?
Scrub with a hand brush instead of using the Little Green's brush.
Pb is offline   Reply With Quote
Old 03-31-2008, 06:26 AM   #3 (permalink)
I used the recommended formula + hot water
I didn't let it set in for a long time
I did use a hand brush 80% of the itme, but looks like it's not enough.
There got be a better chemical to use than the formula+water. What is it?
Old 03-31-2008, 12:51 PM   #4 (permalink)
Pb
Pb's Avatar
Don't dilute it as much. Use cold water. Let it sit for 5 minutes before vacuuming.
I'm gonna try using some Adams carpet cleaner in my Little Green.
Old 04-01-2008, 12:49 AM   #5 (permalink)
would you recommend 50/50 ? I thought hot water is better for cleaning.
I will go look for some coffee cleaner in some stores. Thanks. Let me know how the Adam carpet cleaner is.
Old 04-01-2008, 01:12 AM   #6 (permalink)
Pb
Pb's Avatar
Hot water is good for oily stains. Cold water is good for most other stains.
You can also try a 1:3 mix of white vinegar and water, instead of the Bissel cleaning solution.
I know it's not your fault, but the fact that the coffee stain is old makes it a lot harder to remove. Letting the coffee dry and soak-in is not good. Fresh spills are a lot easier to fix.
Old 04-01-2008, 01:08 PM   #7 (permalink)
I will try the 1:3 vinegar/ cold water this weekend
Yeah I know fresh spills are easier to clean, but at the time I only had enough money to buy the car. LOL
