Originally Posted by YotaRunner4
Tried the Meguilar's clay bar last week and I am very satisfied with the results. ... Also removed all the little rust specs from the brake pads (the Camry is Super White so the rust specs were more noticeble).
Yes, the clay kit is a nice product that works well. PS: After claying is also a good time to use a paint cleaner to remove additional contamination, prior to a good glaze+wax finish.
PLEASE so not re-use the clay bar that you used to remove the rust specs from the brake pads. save it for just that, or glass cleaning etc. do not re-use it on your paint since it likely contains little bits of rust and that will scratch your paint. I will have nightmares thinking about you claying your car and putting fine scratches all over the paint
