window water spot removel - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-07-2009, 12:49 PM   #1 (permalink)
View bmw855's Photo Gallery
Hi,
I just wash my car under the sun as usual but unfortunately today, when I dry out the all the window it get a lot of water spot between the glass (I try to cleaned outside and inside doesn't work) Can anyone tell me what kind of product should I using to remove them? below is the picture
Thank!
bmw855 is offline   Reply With Quote
Old 07-07-2009, 12:59 PM   #2 (permalink)
must.resist.modding
bandit's Avatar
Gameroom cash: $476710
iTrader Score: 12 reviews
View bandit's Photo Gallery
Dont wash your car under hot sun. If you got water spots on your window, you have it on the car itself too.
CarDomain
Old 07-07-2009, 01:00 PM   #3 (permalink)
'07 XLE
Gameroom cash: $283530
View njerald's Photo Gallery
Gen6
  1. Prepare a 50/50 mixture of water and white vinegar.
  2. Soak a towel in the mixture and wipe down the area, making sure to keep it wet.
  3. Drape the towel on the area for a few minutes so that it stays in contact with the surface.
  4. Repeat the above process for severe spots.
  5. For larger areas such as glass shower doors, pour the mixture into a plastic spray bottle.
  6. Spray the mixture onto the glass, wiping frequently with the towel to help break down the limescale deposits.
  7. Rinse and squeegie the area clean. Then buff dry with a clean cloth.
If spots still are there: Spot-X Hard Water Stain & Spot Remover or a similar product
Old 07-07-2009, 01:35 PM   #4 (permalink)
"Circle of trust"
View catric69's Photo Gallery
This should be moved to the "detailing & car care" section of this forum.
catric69 is offline   Reply With Quote
Old 07-07-2009, 02:18 PM   #5 (permalink)
Gameroom cash: $336835
View Redline_Me's Photo Gallery
The vinegar method works.
Redline_Me is offline   Reply With Quote
Old 07-07-2009, 05:57 PM   #6 (permalink)
Go camry goooooo
DrewsCam's Avatar
Gameroom cash: $184780
View DrewsCam's Photo Gallery
also clay bar will remove it
11/19/2007 Gen 6 08 Camry SE.
Rockland Toyota / Scion Showdown 4.0 Sept 26th
DrewsCam is offline   Reply With Quote
Old 07-08-2009, 01:54 AM   #7 (permalink)
Procrastinating on TN
knj27's Avatar
View knj27's Photo Gallery
vinegar is what people often use on boats and it works well.
'93 Pickup 4x4 22R-E
knj27 is offline   Reply With Quote
Old 07-08-2009, 03:08 PM   #8 (permalink)
G Man
View xxgmsmgxx89's Photo Gallery
just windex, doesnt matter if its foam or liquid. then, wipe totally dry, then use rain x...a lot of it. spray that on a rag or paper towel, wipe it on the windows very liberally (for really bad water marks) and then let it haze for a minute...i wipe it on all my windows first then i start at the first window, and remove it with either a terry towel or paper towels. i never have water marks, and the water beads off when it rains, especially when im on the highway. i dont even use my rain x wipers lol
xxgmsmgxx89 is offline   Reply With Quote
Old 07-08-2009, 06:17 PM   #9 (permalink)
knj27's Avatar
ya rain-x is actually pretty good stuff. slicks up the inside of ceramic paintball barrels too
Old 07-20-2009, 06:45 PM   #10 (permalink)
View gameguru1360's Photo Gallery
yep rain-x works really good. For first time use, I usually put on 2 coats, then just 1 coat every 3 or 4 weeks or so
Totaled 1996 Corolla DX
2009 Nissan Altima 2.5S with Takeda SRI, stock dual exhausts, mesh grille
LED bulbs for dome/map/turn signal/tail light/3rd brake light/back up bulbs
gameguru1360 is offline   Reply With Quote
Old 07-23-2009, 11:52 AM   #11 (permalink)
tkd
View tkd's Photo Gallery
Vinegar and Water....only thing I do is add some rubbing alchohol to the mix. Helps it to evaporate a little quicker and dry without any streaking.
tkd is offline   Reply With Quote
Old 07-23-2009, 12:57 PM   #12 (permalink)
THIS SPACE FOR RENT
humanoid's Avatar
Gameroom cash: $996364
View humanoid's Photo Gallery
I've heard that this stuff seems to work well for water spots.
http://store.fastcommerce.com/frankl...5027003c3.html
humanoid is offline   Reply With Quote
Old 07-23-2009, 02:42 PM   #13 (permalink)
Dogging It
judge34411's Avatar
Gameroom cash: $116690
View judge34411's Photo Gallery
Vinegar and water or rain-x But stop washing in the sun. As said, if it is on the window its on the paint, Should see my black car when sun is out and I try that trick!
judge34411 is offline   Reply With Quote
