What do you use to clean the engine bay? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-31-2009, 05:25 AM   #1 (permalink)
<Insert title here>
View YotaRunner4's Photo Gallery
Curious as to what others are using? I used some cleaner from AutoZone (Engine Bright or something like that - can't exactly rememebr the name) on my Camry. I sprayed it all over like the directions said and when I sprayed it off, it removed the red paint that detailed the words VVT-I on the engine shroud. I wasn't too happy. Anyways, I don't want this to happen to the HL.
'08 Highlander Limited 4X4, Silver Metallic
'07 Camry SE, I4 AT, Super White, Moonroof Package
'97 4Runner SR5 4x4 - Sold 1/2/09 with 164K miles
YotaRunner4 is offline   Reply With Quote
Old 07-31-2009, 05:49 AM   #2 (permalink)
Gameroom cash: $187060
View ronsec's Photo Gallery
I use Simple Green.
08 Highlander Limited, Salsa Red . All options except Nav & DVD. Remote start (dealer installed).
09 Rav4, base.
ronsec is offline   Reply With Quote
Old 07-31-2009, 07:06 AM   #3 (permalink)
View Warr1202's Photo Gallery
I have been using Pledge. I got the idea form the car shows where the guys use pledge on everything including under the hood.
Now this is assumming there is no heavy grease build-up. If it was really dirty I would use something like Simple Green or maybe just W40 to get rid of heavy grime and maintain with pledge. I like the new one for all surfaces.
Warr1202 is offline   Reply With Quote
Old 07-31-2009, 10:07 AM   #4 (permalink)
<Insert title here>
So, using Simple Green, do you spray it on, let it soak, then rinse? I've used SG before, but never on a car...
Old 08-01-2009, 05:17 AM   #5 (permalink)
That's exactly how I do it. Sometimes I mist a little water on it to keep it from drying out. Also works good for brake dust on mag wheels!
09 Rav4, base.
Old 08-01-2009, 09:59 AM   #6 (permalink)
DeWat's Avatar
View DeWat's Photo Gallery
There is another thread similar to this one. The difference being that the other thread is more of the "how to" while this thread is more of the "what to use". I've never cleaned my own engine before, and am thinking about trying the Simple Green route on my '08 Highlander. Am I reading correctly that it is ok to pop the hood, cover the alternator, and spray with a garden hose?
DeWat
DeWat is offline   Reply With Quote
Old 08-01-2009, 11:17 AM   #7 (permalink)
Super Moderator
eyeball96's Avatar
Gameroom cash: $904927
iTrader Score: 59 reviews
Purple Power works well too! Spray on, let soak a few minutes, hose off!
][SIZE="2"96 Camry Coupe LE V6
98 Honda CRV
08 GMC Crew
11 Kia Sportage EX AWD[/SIZE]
eyeball96 is offline   Reply With Quote
Old 08-02-2009, 03:30 AM   #8 (permalink)
Procrastinating on TN
knj27's Avatar
View knj27's Photo Gallery
I'm never a fan of spraying the engine with a hose, even if the alternator is covered. There's plenty of other spots water could make it's way in to that it normally wouldn't.
'93 Pickup 4x4 22R-E
knj27 is offline   Reply With Quote
Old 08-02-2009, 06:51 AM   #9 (permalink)
View skuttduck's Photo Gallery
I was leary of that too, then my uncle (who works on cars), said "What do you think happens when you drive the car in the rain?"
I've done simple green, the degreaser at the car wash, and then most recently I used some turtle wax tire cleaner.
This particular tire cleaner said it is safe to use on all exterior black plastics on the can, so I figured, what the hell. My hoses, and wires have never looked so good.
The majority of the engine bay was cleaned well with the tire cleaner at the car wash. I did not use the high pressure washer to rinse this off. Just drove to the car wash, opened the hood it it with the tire cleaner/engine degreaser, washed the rest of the car, and used the light mist to remove.
Worked great on 9 years of grime under the hood.
skuttduck is offline   Reply With Quote
Old 08-02-2009, 06:56 AM   #10 (permalink)
Super Moderator
eyeball96's Avatar
I've been hosing off engines in my Vehicles for 40 years...never had a problem.
You can't be overly aggressive, and drown the engine with 50 gallons of water tho!
I cover the alternator with a plastic bag, and avoid directly spraying the electrics, fuse boxes and such.
98 Honda CRV
08 GMC Crew
Old 08-02-2009, 04:53 PM   #11 (permalink)
knj27's Avatar
I don't think rainwater makes its way into all the places a blast from the hose would, but doing it delicately with the hose is fine, especially if it is warm out and it is going to dry quickly anyway.
But driving a 4x4 truck I've never been worried about dirt on the engine. If there's grease everywhere that sucks when you try to work on it, but I've never had that problem so I've never worried too much about cleaning it.
Although I will say if you go seriously in the mud and cake it all over then engine that's not gonna be good when you try to work on it either...
Old 08-02-2009, 05:17 PM   #12 (permalink)
View nov0798's Photo Gallery
Ive never covered alternators. There is no reason they cant get wet! Again, I would drown the thing, but spraying them off wont hurt them.
nov0798 is offline   Reply With Quote
Old 08-05-2009, 03:09 PM   #13 (permalink)
View gameguru1360's Photo Gallery
I've been using Simple Green as well as Black Magic. The Black Magic says that you can spray it on and walk away but you can lightly use water to wash away some of the grime lifted by the Black Magic.
Totaled 1996 Corolla DX
2009 Nissan Altima 2.5S with Takeda SRI, stock dual exhausts, mesh grille
LED bulbs for dome/map/turn signal/tail light/3rd brake light/back up bulbs
gameguru1360 is offline   Reply With Quote
Old 08-06-2009, 11:07 AM   #14 (permalink)
'95 Camry V6 XLE
View eddie926's Photo Gallery
Be careful using Simple Green. It can stain aluminum and stainless steel. I'd be especially careful using it on wheels. May work fine on some wheels, but could ruin others.
eddie926 is offline   Reply With Quote
Old 08-06-2009, 08:41 PM   #15 (permalink)
Rapid Roy's Avatar
View Rapid Roy's Photo Gallery
This thread has a great description with pictures about detailing your engine compartment.
Finally got my engine bay finished
Rapid Roy is offline   Reply With Quote
