Yellow line paint on '04 black HL - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-27-2009, 12:02 PM   #1 (permalink)
Gameroom cash: $266140
View shortlid's Photo Gallery
Thumbs down Yellow line paint on '04 black HL
Well looked at the drivers side of my black '04 HL and it has fine Yellow road line paint spray on the lowwer rockers and drivers door bottom. I have tried bug and tar remover without much luck, only thing that takes it off is my finder nail, don't want to scratch my fragile black paint. Is clay bar a better option? Any other ticks folks!!
I have wanted to put longer flat/truck style mudflaps on my HL for just this reason, the stock contour ones don't cut it!
Use to work for TMMI, own a '04 Highlander V6, 4WD, 3rd row, now has 125k on the clock.
My family in-law has a '97 Tercel CE Coupe, '03 Tacoma DC, '07 Highlander V6, 4WD, 7 pass. and a '04 Sienna LE!
shortlid is offline   Reply With Quote
Old 11-27-2009, 06:05 PM   #2 (permalink)
THIS SPACE FOR RENT
humanoid's Avatar
Gameroom cash: $996364
View humanoid's Photo Gallery
Try the clay bar, I've heard it takes overspray off, so it might work, it couldn't hurt.
humanoid is offline   Reply With Quote
Old 11-28-2009, 01:39 AM   #3 (permalink)
OEM+
eyezack87's Avatar
Gameroom cash: $207080
iTrader Score: 7 reviews
View eyezack87's Photo Gallery
You should be able to remove most of it with some paint thinner or something like it. Just make sure its a quick wipe after you put it on or you risk messing up your paint. I did it a couple times to my ES when I didn't want to waste a perfectly good/rare/expensive claybar that I have in my stock lol
1996 Beige Lexus ES300
2010 Blue Ribbon Metallic Camry LE
eyezack87 is offline   Reply With Quote
Old 12-02-2009, 10:26 PM   #4 (permalink)
on full afterburner
Gameroom cash: $1337497
I'd rather waste a claybar than risk causing damage to my paint wiping it with thinner.
Old 12-03-2009, 01:44 PM   #5 (permalink)
AdamsCL's Avatar
View AdamsCL's Photo Gallery
USA
Try using prep clean as a solvent and a plastic razor blade, if necessary. Both are usually sold at most auto parts stores. To save time, you could always just spray paint black any areas that are in the wheel wells. Follow up with a rubbing compound or good polish, if nededed, and finish with a good quality wax or sealant. Good Luck!
2008 Highlander Limited AWD, Classic Silver Metallic, Ash Leather, SmartKey, JBL/Bluetooth, Tow Package, Debadged Power Rear Door - Accessories: Toyota VIP Remote Start, Mud Guards, Valor Exhaust Tip
AdamsCL is offline   Reply With Quote
Old 12-04-2009, 09:40 AM   #6 (permalink)
GO KING'S GO!
dktaco's Avatar
View dktaco's Photo Gallery
Don't use paint thinner. Use a clay bar with the proper quick detailer and you will get it off. Just cut a piece of the bar use that then toss it.
dktaco is offline   Reply With Quote
Old 12-04-2009, 10:46 AM   #7 (permalink)
Thanks
Did seem to dirty the bar quick.
Old 12-05-2009, 01:29 AM   #8 (permalink)
View lefty101's Photo Gallery
use non clorinated brake cleaner then polish after....
lefty101 is offline   Reply With Quote
Old 12-05-2009, 11:02 PM   #9 (permalink)
OEM+
eyezack87's Avatar
You guys should keep an open mind to ideas lol. Essentially, 3M adhesive remover will work but its expensive
