Originally Posted by Mr. G
Sorry, but I was not very happy on how this person use a rotary and showing the wrong way of it's use. 3M Super Duty is know as Rocks In the Bottle so be very careful with it..........I'm going to walk the dog.................
Amen.
Rubbing compound should be outlawed. It's way too aggressive...even something as mild as Meguiar's M205 would take off that oxidation just fine with a wool pad and a rotary. Using M105 would be super-easy.
"The trick is to...uh...balance the amount you are taking off with the amount of paint you have on".
Yes, that is the trick, but how does one do this? He doesn't tell us; he just warns us that seeing metal after you buff would confirm that you don't "know the trick".
One way to not polish down to the metal is not do use a diminishing abrasive compound (see comments above).
The water "activates the compound"? Do you mean if we don't add water, it doesn't work?
Also, he recommended angling the pad to get into the cracks and crevices? That's a good way to burn through an edge!
"Never hold the pad flat"? Wrong again. To get a swirl-free finish, you need to come down off the edge.
I stopped the video after that.
