Washing and buffing... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-30-2010, 07:59 AM   #1 (permalink)
湾岸ミドナイット - 又しすぎる。
Raymond_Tengen's Avatar
View Raymond_Tengen's Photo Gallery
Last weekend, I washed my car thoroughly. I removed scratches on the door handles by applying scratch remover on a pad by hand. Finally, I waxed my car also by hand. My arms became very sore after that but I thought, at the time, the effort was worth it.
During the last two days, it rained a lot in Montreal. The water was gliding very smoothly but not every part of the car does it though. I also noticed some water marks on the body, but a lot less than before. I wonder if it was caused by an uneven wax application due to my sore arms at the time. And of course, I should've bought and use a clay bar to remove accumulated contaminants over time (two years). And to make everything shine, I thought I might use a quick detailer at the end to make the "blackness" stand out like it used to.
My questions are
1. Should I apply the scratch remover before or after claying (common sense tells me "after claying")?
2. Should I get myself a rotary buffer instead to apply the scratch remover and wax?
3. What rotary buffer would you recommend for someone who never used one before?
Thanks~
L.
Raymond_Tengen is offline   Reply With Quote
Old 07-03-2010, 03:02 PM   #2 (permalink)
'94 Camry V6/'02 Sequoia
View ToyotaJimD.'s Photo Gallery
You can't really expect even beading due to variables in the rain, the direction it's raining, how it flows from the top to the bottom of the vehicle, and so on.
And it could be due in part to your arms getting tired.
Rotaries are not recommended except in expert hands and for polishing.
If you're getting tired during waxing, try the PowerBall 4Paint from Mothers to apply the product. Remove by hand. Really makes the job easy.
If you're using a scratch remover, I'd do it after claying so you're working with a clean surface.
1994 Camry V6 XLE - Cashmere Beige
2002 Sequoia - White
ToyotaJimD. is offline   Reply With Quote
Old 07-03-2010, 08:11 PM   #3 (permalink)
View Shelbrain's Photo Gallery
I would recommend a Porter Cable 7424. I use Lake Country pads. I learned all about detailing from www.autopia.org
Shelbrain is offline   Reply With Quote
Old 07-08-2010, 06:00 AM   #4 (permalink)
GO RED SOX!
Dana_15's Avatar
Gameroom cash: $219406
iTrader Score: 9 reviews
View Dana_15's Photo Gallery
Agreed. I use mine all the time, excellent results. Using the PC will get you a much more even shine....
Dana_15 is offline   Reply With Quote
Old 07-08-2010, 07:32 AM   #5 (permalink)
湾岸ミドナイット - 又しすぎる。
Is PC 7424 easy to use (aside from having a firm grip so that it does not fly around)? I've never used any of these before.
L.
Old 07-08-2010, 10:08 PM   #6 (permalink)
on full afterburner
Gameroom cash: $1337497
It's easy to use if you can read and follow the instruction manual.
