Stain on cafr carpet - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-26-2010, 03:25 AM   #1 (permalink)
Gameroom cash: $118425
View Mag Grey Toy's Photo Gallery
recently i got a fruitpunch stain on the car carpet (not the mat)
ive tried a couple of different stain removers but it doesnt seem to want to lift. Any suggestions?
thanks.
Mag Grey Toy is offline   Reply With Quote
Old 08-26-2010, 03:18 PM   #2 (permalink)
THIS SPACE FOR RENT
humanoid's Avatar
Gameroom cash: $996364
View humanoid's Photo Gallery
Try rubbing some Oxy Clean on it. Put some in a bowl or other container, put a bit of water in it to make it into some sort of paste and apply it on the stain. Rub it in there good with a cleaning brush or something similar.
This is my sig.
humanoid is offline   Reply With Quote
Old 08-27-2010, 01:55 AM   #3 (permalink)
aite just got some oxyclean hopeing it will work
ill let you know the results
Old 08-31-2010, 02:02 AM   #4 (permalink)
no luck it looks like it set in.
thanks anyways guys
Old 08-31-2010, 02:32 AM   #5 (permalink)
Do you feel lucky?
TrailDust's Avatar
Gameroom cash: $3622550
Don't give up until you've tried Folex. I just recently used it to remove two cat puke stains that had set into my sister's carpet, worked like a charm.
2008 Highlander Base 4WD
2002 Avalon XL
TrailDust is online now   Reply With Quote
Old 08-31-2010, 04:55 AM   #6 (permalink)
Super Moderator
eyeball96's Avatar
Gameroom cash: $904927
iTrader Score: 59 reviews
I've successfully removed stains from carpet with "Greased Lighting"...worth a try, nothing to loose
][SIZE="2"96 Camry Coupe LE V6
98 Honda CRV
08 GMC Crew
11 Kia Sportage EX AWD[/SIZE]
Old 09-01-2010, 12:46 AM   #7 (permalink)
where did you guys get these products?
any store known to caryr them?
ima see if i can get the Folex online right now,.
edit
nvm found a list
ima try to pic one up tmw and try it
if i got no luck ill try the Greased Lighting
Old 09-01-2010, 11:27 AM   #8 (permalink)
Do you feel lucky?
TrailDust's Avatar
You can find Folex at Walmart, Home Depot, or True Value Hardware.
2002 Avalon XL
Old 09-03-2010, 09:01 PM   #9 (permalink)
gahh its been set in folex no help now
thanks alot guys
i tried my best
good thing its in a hiddenspot under the mat >.<
Old 09-03-2010, 09:34 PM   #10 (permalink)
Do you feel lucky?
TrailDust's Avatar
Wow, that must be some stain! Only thing that Folex didn't get out for me was blood that had set in. Interesting to know what it can't get out.
2002 Avalon XL
Old 09-04-2010, 12:47 AM   #11 (permalink)
i think its most likely that it set in :/
i prolly didnt get to it in time
but now im prepaired for any other stains that come my way
the folex is sitting in my trunk atm xD
thanks for the tip on it
Old 10-20-2010, 10:09 PM   #12 (permalink)
Andele, andele!
speedy25's Avatar
Gameroom cash: $235245
View speedy25's Photo Gallery
I know I'm a couple of months late on this post but I normally dont troll around.
NOTHING on the store shelves will remove RED stains from carpet. The red food dye actually dyes the carpet, BUT it can be removed. If you were in my neighborhood, I could handle it quick and easy. Call a carpet cleaning pro and ask about getting red stains out. If he mentions he has a product called "red relief" he can do it. Removing red stains requires heat. If the guy you get doesnt break out an iron with his magic chemicals, send him on his way. He doesnt know what to do.
And to add to stain removal advice- DO NOT USE ANY OXYGENATED PRODUCTS!!!!
Yes, you may get the stain out, but it has a side effect they dont tell you about- Its not UV stable! After the sun hits it it changes color.
-Pete the Carpet Guy
