OEM mud flaps on '04 Highander wore paint off!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-15-2010, 03:46 PM   #1 (permalink)
Gameroom cash: $266140
View shortlid's Photo Gallery
Finaly got around to taking the stock molded flaps off my '04 HL 4WD and was VERY disapointed that not only was there a 1/4 inch of caked dirt behind them. But where the molded flap meets the body the mud OEM mud flaps rubbed the paint down the bare metal!!! Now have to touch up the truck to keep it from rusting out along the mud flap. Anyone have a tip to keep this from happening again??
Use to work for TMMI, own a '04 Highlander V6, 4WD, 3rd row, now has 125k on the clock.
My family in-law has a '97 Tercel CE Coupe, '03 Tacoma DC, '07 Highlander V6, 4WD, 7 pass. and a '04 Sienna LE!
shortlid is offline   Reply With Quote
Old 11-15-2010, 03:51 PM   #2 (permalink)
CERTIFIABLE CAR NUT
Zembonez's Avatar
Gameroom cash: $609731
View Zembonez's Photo Gallery
That sucks... but anything that traps dirt like that can and will wear off the paint. I'd touch it up and reinstall them with a small bead of silicone on about 50% of the area that touches the body. It should keep the flap from moving against the paint and yet still allow moisture to escape if you just place the bead in the center.
Zembonez is offline   Reply With Quote
The Following User Says Thank You to Zembonez For This Useful Post:
shortlid (11-16-2010)
Old 11-16-2010, 01:53 PM   #3 (permalink)
Thanks, also the factory flap has a air by pass that let all the road tar attach it self to the finish under the molded part of the flap. Guess just bug and tar and then clay bar is best to remove that!
What type of clear silicone can I use to make sure it does not lift the paint if I ever have to remove the mud flaps again?
